The number of directions determined by a function f on a finite field, Journal of Combinatorial Theory, Series A, vol.70, issue.2, pp.70-349, 1995. ,
DOI : 10.1016/0097-3165(95)90100-0
Permutations amongst the Dembowski-Ostrom polynomials, Finite fields and applications, pp.37-42, 1999. ,
Charpin and Y. Laigle-Chapuy, On almost perfect nonlinear functions over F n 2, IEEE Trans. Inform. Theory, vol.52, issue.9, pp.4160-4170, 2006. ,
Finite field elements with specified order and traces, Des. Codes Cryptogr, pp.331-340, 2005. ,
Commutative presemifields and semifields, Advances in Mathematics, vol.217, issue.1, pp.282-304, 2008. ,
DOI : 10.1016/j.aim.2007.07.007
Planar functions and planes of Lenz-Barlotti class II, Des. Codes Cryptogr, pp.167-184, 1997. ,
Planes of ordern with collineation groups of ordern 2, Mathematische Zeitschrift, vol.7, issue.3, pp.239-258, 1968. ,
DOI : 10.1007/BF01111042
Signal Sets From Functions With Optimum Nonlinearity, IEEE Transactions on Communications, vol.55, issue.5, pp.936-940, 2007. ,
DOI : 10.1109/TCOMM.2007.894113
A Family of Optimal Constant-Composition Codes, IEEE Transactions on Information Theory, vol.51, issue.10, pp.51-3668, 2005. ,
DOI : 10.1109/TIT.2005.855609
On a family of perfect nonlinear binomials, in " Boolean Functions in Cryptology and Information Security, pp.126-139, 2008. ,
On certain diagonal equations over finite fields, Finite Fields Appl, pp.633-643, 2009. ,
A Note on a Class of Quadratic Permutations over ${\mathbb F}_{{2^n}}$, Lecture Notes in Comput. Sci, vol.4851, pp.130-137, 2007. ,
DOI : 10.1007/978-3-540-77224-8_17
Constructing permutations of finite fields via linear translators, Journal of Combinatorial Theory, Series A, vol.118, issue.3 ,
DOI : 10.1016/j.jcta.2010.08.005
Some Theorems on Planar Mappings, LNCS, vol.5130, pp.117-122, 2008. ,
DOI : 10.1007/978-3-540-69499-1_10
Rational Points on Curves over Finite Fields: Theory and Applications, 2001. ,
DOI : 10.1017/CBO9781107325951
Differentially uniform mappings for cryptography, Advances in Cryptology-EUROCRYPT 93, pp.134-144, 1994. ,
DOI : 10.1007/3-540-48285-7_6
Algebraic Function Fields and Codes, 2009. ,
Pseudo-Paley graphs and skew Hadamard difference sets from presemifields, Designs, Codes and Cryptography, vol.11, issue.228, pp.49-62, 2007. ,
DOI : 10.1007/s10623-007-9057-6
