On Lov??sz??? lattice reduction and the nearest lattice point problem, Combinatorica, vol.357, issue.1, pp.1-13, 1986. ,
DOI : 10.1007/BF02579403
New bounds in some transference theorems in the geometry of numbers, Mathematische Annalen, vol.68, issue.1, pp.625-635, 1993. ,
DOI : 10.1007/BF01445125
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.235-265, 1997. ,
DOI : 10.1006/jsco.1996.0125
On maximum-likelihood detection and the search for the closest lattice point (English summary), IEEE Trans. Inform. Theory, vol.49, pp.2389-2402, 2003. ,
Lattice coding and decoding achieve the optimal diversity-multiplexing tradeoff of MIMO channels (English summary), IEEE Trans. Inform. Theory, vol.50, pp.968-985, 2004. ,
On the Sphere Problem, Revista Matem??tica Iberoamericana, vol.11, pp.417-429, 1995. ,
DOI : 10.4171/RMI/178
Geometry and the imagination, 1999. ,
Soft decoding techniques for codes and lattices, including the Golay code and the Leech lattice, IEEE Transactions on Information Theory, vol.32, issue.1, pp.41-50, 1986. ,
DOI : 10.1109/TIT.1986.1057135
Sphere packings, lattices and groups, Grundlehren der mathematischen Wissenschaften, vol.290, 1988. ,
On the covering multiplicity of lattices, Discrete & Computational Geometry, vol.1, issue.1, pp.109-130, 1992. ,
DOI : 10.1007/BF02293039
Spherical codes and designs, Geometriae Dedicata, vol.18, issue.3, pp.363-388, 1977. ,
DOI : 10.1007/BF03187604
Improved methods for calculating vectors of short length in a lattice, including a complexity analysis, Mathematics of Computation, vol.44, issue.170, pp.463-471, 1985. ,
DOI : 10.1090/S0025-5718-1985-0777278-8
Coset Codes -Part II: Binary lattices and related codes. Coding techniques and coding theory, IEEE Trans. Inform. Theory, vol.5, pp.1152-1187, 1988. ,
Rank 72 high minimum norm lattices, J. Number Theory, vol.130, pp.1512-1519, 2010. ,
The complexity of the covering radius problem, computational complexity, vol.14, issue.2, pp.90-121, 2005. ,
DOI : 10.1007/s00037-005-0193-y
Lattice points in the sphere. Number theory in progress 2, pp.883-892, 1999. ,
An even unimodular 72-lattice with minimum 8, J. Reine und Angew. Math ,
A construction of integral lattices, Mathematika, vol.23, issue.01, pp.137-140, 1984. ,
DOI : 10.2307/2007025
Counting Lattice Points in The Sphere, Bulletin of the London Mathematical Society, vol.32, issue.6, pp.679-688, 2000. ,
DOI : 10.1112/S0024609300007505
Hadamard matrices, Baumert-Hall units, four-symbol sequences, pulse compression, and surface wave encodings, Journal of Combinatorial Theory, Series A, vol.16, issue.3, pp.313-333, 1974. ,
DOI : 10.1016/0097-3165(74)90056-9
