Abstract : This paper introduces a reconstruction approach for the input signal of an oversampled filter bank (OFB) when the sub-bands generated at its output are quantized and transmitted over a noisy channel. This approach exploits the redundancy introduced by the OFB and the fact that the quantization noise is bounded. A maximum-likelihood estimate of the input signal is evaluated, which only considers the vectors of quantization indexes corresponding to subband signals that could have been generated by the OFB and that are compliant with the quantization errors. When considering an OFB with an oversampling ratio of 3/2 and a transmission of quantized subbands on an AWGN channel, compared to a classical decoder, the performance gains are up to 9 dB in terms of SNR for the reconstructed signal, and 3 dB in terms of channel SNR.
https://hal.inria.fr/inria-00614541
Contributor : Michel Kieffer <>
Submitted on : Monday, August 29, 2011 - 1:59:02 AM Last modification on : Monday, October 19, 2020 - 9:24:17 AM Long-term archiving on: : Wednesday, November 30, 2011 - 2:20:18 AM
Manel Abid, Michel Kieffer, Beatrice Pesquet-Popescu. Consistent Reconstruction of the Input of an Oversampled Filter Bank From Noisy Subbands. European Signal Processing Conference, Aug 2011, Barcelone, Spain. ⟨inria-00614541⟩
