A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
DOI : 10.1002/j.1538-7305.1948.tb01338.x
Joint source-channel decoding: A cross-layer perspective with applications in video broadcasting, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00548148
Joint Source-Channel Video Transmission, 2007. ,
Oversampled filterbanks: Optimal noise shaping, design freedom and noise analysis, Proc. IEEE Conf. on Acoust. Speech Signal Process, pp.2453-2456, 1997. ,
Oversampled filter banks, IEEE Transactions on Signal Processing, vol.46, issue.5, pp.1245-1255, 1998. ,
DOI : 10.1109/78.668788
Quantized overcomplete expansions in IR/sup N/: analysis, synthesis, and algorithms, IEEE Transactions on Information Theory, vol.44, issue.1, pp.16-31, 1998. ,
DOI : 10.1109/18.650985
Computer Networking: A Top-Down Approach Featuring the Internet, 2005. ,
Filter bank frame expansions with erasures, IEEE Transactions on Information Theory, vol.48, issue.6, pp.1439-1450, 2002. ,
DOI : 10.1109/TIT.2002.1003832
Frame-Theoretic Analysis of DFTCodes With Erasures, IEEE Transactions on Signal Processing, vol.52, issue.2, pp.447-460, 2004. ,
DOI : 10.1109/TSP.2003.821106
Comparison of redundant wavelet schemes for multiple description coding of wavelet sequences, Proc. IEEE ICASSP, pp.913-916, 2005. ,
Recovering the output of an OFB in the case of instantaneous erasures in sub-band domain, 2010 IEEE International Workshop on Multimedia Signal Processing, pp.274-279, 2010. ,
DOI : 10.1109/MMSP.2010.5662032
Analysis of the effect of impulse noise on multicarrier and single carrier QAM systems, IEEE Transactions on Communications, vol.44, issue.2, pp.145-147, 1996. ,
DOI : 10.1109/26.486604
Oversampled filter banks as error correcting codes: theory and impulse noise correction, IEEE Transactions on Signal Processing, vol.53, issue.12, pp.4619-4630, 2005. ,
DOI : 10.1109/TSP.2005.859314
Decoding real-number convolutional codes: change detection, Kalman estimation, IEEE Transactions on Information Theory, vol.43, issue.6, pp.1864-1876, 1997. ,
DOI : 10.1109/18.641552
Wavelet Codes: Detection and Correction Using Kalman Estimation, IEEE Transactions on Signal Processing, vol.57, issue.4, pp.1339-1350, 2009. ,
DOI : 10.1109/TSP.2008.2011838
Source and Channel Coding: An Algorithmic Approach, 1991. ,
DOI : 10.1007/978-1-4615-3998-8
Applied Interval Analysis, 18] P. P. Vaidyanathan, Multirate Systems and Filterbanks, 1993. ,
DOI : 10.1007/978-1-4471-0249-6
URL : https://hal.archives-ouvertes.fr/hal-00845131
Identification of Parametric Models from Experimental Data, 1997. ,
