Package Fingerprints: A visual summary of package interface usage, Information and Software Technology, vol.52, issue.12, pp.1312-1330, 2010. ,
DOI : 10.1016/j.infsof.2010.07.005
URL : https://hal.archives-ouvertes.fr/hal-00530778
Automatic Package Coupling and Cycle Minimization, 2009 16th Working Conference on Reverse Engineering, pp.103-112, 2009. ,
DOI : 10.1109/WCRE.2009.13
URL : https://hal.archives-ouvertes.fr/inria-00425417
Coupling and cohesion as modularization drivers: are we being over-persuaded?, Fifth Europ. Conf. on Sof. Maintenance and Reengineering, pp.47-57, 2001. ,
Measuring coupling and cohesion of software modules: an information-theory approach, Proceedings Seventh International Software Metrics Symposium, 2001. ,
DOI : 10.1109/METRIC.2001.915521
Predicting maintenance performance using object-oriented design complexity metrics, IEEE Transactions on Software Engineering, vol.29, issue.1, pp.77-87, 2003. ,
DOI : 10.1109/TSE.2003.1166590
Cohesion and reuse in an object-oriented system, ACM Symposium on Software Reusability, 1995. ,
Measuring design-level cohesion, IEEE Transactions on Software Engineering, vol.24, issue.2, pp.111-124, 1998. ,
DOI : 10.1109/32.666825
A Unified Framework for Cohesion Measurement in Object-Oriented Systems. Empirical Software Engineering, An International Journal, vol.3, issue.1, pp.65-117, 1998. ,
A unified framework for coupling measurement in object-oriented systems, IEEE Transactions on Software Engineering, vol.25, issue.1, pp.91-121, 1999. ,
DOI : 10.1109/32.748920
Defining and validating measures for object-based high-level design, IEEE Transactions on Software Engineering, vol.25, issue.5, pp.722-743, 1999. ,
DOI : 10.1109/32.815329
Modularity: Understanding the Development and Evolution of Natural Complex Systems, p.5 ,
A metrics suit for object oriented design, IEEE TSE, vol.20, pp.476-493, 1994. ,
Software metrics for object-oriented systems, Proceedings of the 1992 ACM annual conference on Communications , CSC '92, pp.317-322, 1992. ,
DOI : 10.1145/131214.131254
Predicting maintainability with objectoriented metrics -an empirical comparison, 10th Work. Conf. on Rev. Eng., WCRE '03, pp.155-164, 2003. ,
An object-oriented high-level design-based class cohesion metric, Information and Software Technology, vol.52, issue.12, pp.1346-1361, 2010. ,
DOI : 10.1016/j.infsof.2010.08.006
Programming in the large versus programming in the small, IEEE TSE, vol.2, issue.2, pp.80-86, 1976. ,
Package Surface Blueprints: Visually Supporting the Understanding of Package Relationships, 2007 IEEE International Conference on Software Maintenance, pp.94-103 ,
DOI : 10.1109/ICSM.2007.4362622
Candidate metrics for object-oriented software within a taxonomy framework, Journal of Systems and Software, vol.26, issue.1, pp.87-96, 1994. ,
DOI : 10.1016/0164-1212(94)90099-X
Does code decay? Assessing the evidence from change management data, IEEE Transactions on Software Engineering, vol.27, issue.1, pp.1-12, 2001. ,
DOI : 10.1109/32.895984
A discriminant metric for module cohesion, ICSE, 1984. ,
Reducing coupling, IEEE Software, vol.18, issue.4, 2001. ,
DOI : 10.1109/MS.2001.936226
Evaluation of coupling in the context of java interfaces, the conf. on OO prog., sys., lang., and app. (Addendum), OOPSLA '00, pp.47-48, 2000. ,
Automated assistance for program restructuring, ACM Transactions on Software Engineering and Methodology, vol.2, issue.3, pp.228-269, 1993. ,
DOI : 10.1145/152388.152389
Improving Java software through package structure analysis, Int. Conf. Sof. Eng. and App, 2002. ,
Object-Oriented Metrics: Measures of Complexity, 1996. ,
Cohesion as changeability indicator in object-oriented systems, Proceedings Fifth European Conference on Software Maintenance and Reengineering, pp.39-46, 2001. ,
DOI : 10.1109/CSMR.2001.914966
Another metric suite for object-oriented programming, Journal of Systems and Software, vol.44, issue.2, pp.155-162, 1998. ,
DOI : 10.1016/S0164-1212(98)10052-3
Object-oriented metrics that predict maintainability, Journal of Systems and Software, vol.23, issue.2, pp.111-122, 1993. ,
DOI : 10.1016/0164-1212(93)90077-B
The tipping point: Stability and instability in oo design, 05 ,
Agile Software Development. Principles, Patterns, and Practices, 2002. ,
Cohesion is structural, coherence is functional: Different views, different measures, Int. Sof. Metrics Symposium. IEEE, 2001. ,
On the criteria to be used in decomposing systems into modules, Communications of the ACM, vol.15, issue.12, pp.1053-1058, 1972. ,
DOI : 10.1145/361598.361623
A measure for composite module cohesion, Proceedings of the 14th international conference on Software engineering , ICSE '92, pp.38-48, 1992. ,
DOI : 10.1145/143062.143086
Using context information to re-architect a system, 3rd Sof. Measur. Europ. Forum, pp.91-103 ,
Metrics for Measuring the Quality of Modularization of Large-Scale Object-Oriented Software, IEEE Transactions on Software Engineering, vol.34, issue.5, pp.700-720 ,
DOI : 10.1109/TSE.2008.43
Api-based and informationtheoretic metrics for measuring the quality of software modularization, IEEE TSE, vol.33, issue.1, pp.14-32 ,
The java module system: Core design and semantic definition, OO Prog. Sys., Lang. and App, vol.42, issue.10, pp.499-514 ,
Jsr-294: Improved modularity support in the java programming language ,
