Damaris: Leveraging Multicore Parallelism to Mask I/O Jitter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
With exascale computing on the horizon, the performance variability of I/O systems represents a key challenge in sustaining high performance. In many HPC applications, I/O is concurrently performed by all processes, which leads to I/O bursts. This causes resource contention and substantial variability of I/O performance, which significantly impacts the overall application performance together with the predictability of its run time. In this paper, we first illustrate the presence of I/O jitter on different platforms, and show the impact of different user-configurable parameters and I/O approaches on write performance variability. We then propose a new approach to I/O, called Damaris, which leverages dedicated I/O cores on each multicore SMP node, along with the use of shared-memory, to efficiently perform asynchronous data processing and I/O. We evaluate our approach on three different platforms including the Kraken Cray XT5 supercomputer, with the CM1 atmospheric model, which is one of the target HPC applications for the Blue Waters project. By overlapping I/O with computation and by gathering data into large files while avoiding synchronization between cores, our solution brings several benefits: 1) it fully hides the jitter as well as all I/O-related costs, which makes simulation performance predictable; 2) it increases the sustained write throughput by a factor of 15 compared to standard approaches; 3) it allows almost perfect scalability of the simulation where other I/O approaches fail to scale; 4) it enables a 600% compression ratio without any additional overhead, leading to a major reduction of storage requirements.
RR-7706.pdf (967.44 Ko) Télécharger le fichier
inria-00614597 , version 1 (12-08-2011)
inria-00614597 , version 2 (06-12-2011)
inria-00614597 , version 3 (09-04-2012)
  • HAL Id : inria-00614597 , version 3
Matthieu Dorier, Gabriel Antoniu, Franck Cappello, Marc Snir, Leigh Orf. Damaris: Leveraging Multicore Parallelism to Mask I/O Jitter. [Research Report] RR-7706, INRIA. 2012, pp.36. ⟨inria-00614597v3⟩
1040 Consultations
404 Téléchargements
