Invariant pattern recognition: A review, Pattern Recognition, vol.29, issue.1, pp.1-17, 1996. ,
DOI : 10.1016/0031-3203(95)00069-0
Review of shape representation and description techniques, Pattern Recognition, vol.37, issue.1, pp.1-19, 2004. ,
DOI : 10.1016/j.patcog.2003.07.008
Fourier transforms, " in The Transforms and Applications Handbook, 2000. ,
The Mellin transform, " in The Transforms and Applications Handbook, A. D. Poularikas, 2000. ,
Rotation-invariant digital pattern recognition using circular harmonic expansion, Applied Optics, vol.21, issue.22, pp.4012-4015, 1982. ,
DOI : 10.1364/AO.21.004012
Shape-based image retrieval using generic Fourier descriptor, Signal Processing: Image Communication, pp.825-848, 2002. ,
DOI : 10.1016/S0923-5965(02)00084-X
Image analysis via the general theory of moments*, Journal of the Optical Society of America, vol.70, issue.8, pp.920-930, 1980. ,
DOI : 10.1364/JOSA.70.000920
Moments and Moment Invariants in Pattern Recognition, 2009. ,
DOI : 10.1002/9780470684757
Identification of Reflected, Scaled, Translated, and Rotated Objects From Their Radon Projections, IEEE Transactions on Image Processing, vol.17, issue.3, pp.301-310, 2008. ,
DOI : 10.1109/TIP.2007.916160
A new shape descriptor defined on the Radon transform, Computer Vision and Image Understanding, vol.102, issue.1, pp.42-51, 2006. ,
DOI : 10.1016/j.cviu.2005.06.005
URL : https://hal.archives-ouvertes.fr/inria-00000643
Scaling and rotation invariant analysis approach to object recognition based on Radon and Fourier???Mellin transforms, Pattern Recognition, vol.40, issue.12, pp.3503-3508, 2007. ,
DOI : 10.1016/j.patcog.2007.04.020
Rotation-invariant texture analysis using Radon and Fourier transforms, Journal of Physics: Conference Series, vol.48, issue.1 1, p.1459, 2007. ,
DOI : 10.1088/1742-6596/48/1/268
Invariant pattern recognition using radon, dual-tree complex wavelet and Fourier transforms, Pattern Recognition, vol.42, issue.9, pp.2013-2019, 2009. ,
DOI : 10.1016/j.patcog.2008.10.008
Rotation invariant analysis and orientation estimation method for texture classification based on Radon transform and correlation analysis, Journal of Visual Communication and Image Representation, vol.21, issue.1, pp.29-32, 2010. ,
DOI : 10.1016/j.jvcir.2009.09.010
Use of the Hough transformation to detect lines and curves in pictures, Communications of the ACM, vol.15, issue.1, pp.11-15, 1972. ,
DOI : 10.1145/361237.361242
The Radon transform and its application to shape parametrization in machine vision, Image and Vision Computing, vol.5, issue.2, pp.161-166, 1987. ,
DOI : 10.1016/0262-8856(87)90044-8
Use of the Radon transform as a method of extracting information about shape in two dimensions, Image and Vision Computing, vol.10, issue.2, pp.99-107, 1992. ,
DOI : 10.1016/0262-8856(92)90004-M
Invariant description and retrieval of planar shapes using Radon composite features, IEEE Transactions on Signal Processing, vol.56, issue.1, pp.10-11, 2008. ,
The Trace transform and its applications, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.8, pp.811-828, 2001. ,
DOI : 10.1109/34.946986
Affine invariant features from the trace transform, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.1, pp.30-44, 2004. ,
DOI : 10.1109/TPAMI.2004.1261077
A Geometric Invariant Shape Descriptor Based on the Radon, Fourier, and Mellin Transforms, 2010 20th International Conference on Pattern Recognition, pp.2085-2088, 2010. ,
DOI : 10.1109/ICPR.2010.512
URL : https://hal.archives-ouvertes.fr/inria-00512312
Scale & Affine Invariant Interest Point Detectors, International Journal of Computer Vision, vol.60, issue.1, pp.63-86, 2004. ,
DOI : 10.1023/B:VISI.0000027790.02288.f2
URL : https://hal.archives-ouvertes.fr/inria-00548554
Image retrieval based on multi-texton histogram, Pattern Recognition, vol.43, issue.7, pp.2380-2389, 2010. ,
DOI : 10.1016/j.patcog.2010.02.012
The Radon Transform and Some of Its Applications, 1993. ,
New optical transforms for pattern recognition, Proceedings of the IEEE, vol.65, issue.1, pp.77-84, 1977. ,
DOI : 10.1109/PROC.1977.10432
Circular-Fourier???radial-Mellin transform descriptors for pattern recognition, Journal of the Optical Society of America A, vol.3, issue.6, pp.885-888, 1986. ,
DOI : 10.1364/JOSAA.3.000885
The Fourier???Mellin transform and mammalian hearing, The Journal of the Acoustical Society of America, vol.63, issue.1, pp.174-183, 1978. ,
DOI : 10.1121/1.381708
A New Implementation of the Mellin Transform and its Application to Radar Classification of Ships, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.5, issue.2, pp.191-199, 1983. ,
DOI : 10.1109/TPAMI.1983.4767371
Invariant image recognition by Zernike moments, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.5, pp.489-497, 1990. ,
DOI : 10.1109/34.55109
On the generalised distance in statistics, Proceedings of the National Institute of Sciences of India, pp.49-55, 1936. ,
A fast digital radon transform???an efficient means for evaluating the hough transform, Pattern Recognition, vol.29, issue.4, pp.711-718, 1996. ,
DOI : 10.1016/0031-3203(96)00015-5
A Fast Discrete Approximation Algorithm for the Radon Transform, SIAM Journal on Computing, vol.27, issue.1, pp.107-119, 1998. ,
DOI : 10.1137/S0097539793256673
Fast Slant Stack: A Notion of Radon Transform for Data on A Cartesian Grid Which Is Rapidly Computable, Algebraically Exact, Geometrically Faithful, and Invertible, 2001. ,
Robust and Efficient Fourier???Mellin Transform Approximations for Gray-Level Image Reconstruction and Complete Invariant Description, Computer Vision and Image Understanding, vol.83, issue.1, pp.57-78, 2001. ,
DOI : 10.1006/cviu.2001.0922
A fast Mellin and scale transform, EURASIP Journal on Advances in Signal Processing, issue.42, 2007. ,
Inverse filtering for linear shift-variant imaging systems, Proceedings of the IEEE, pp.862-872, 1972. ,
DOI : 10.1109/PROC.1972.8785
The Shift and Scale Invariant Fourier-Mellin Transform for Radar Applications, Massachusetts Institute of Technology, Tech. Rep, issue.42, 1980. ,
Rotation-invariant multiresolution texture analysis using Radon and wavelet transforms, IEEE Transactions on Image Processing, vol.14, issue.6, pp.783-795, 2005. ,
DOI : 10.1109/TIP.2005.847302
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2661821
Columbia Object Image Library (COIL-20), CUCS-005-96, 1996. ,
Applying algebraic and differential invariants for logo recognition, Machine Vision and Applications, vol.17, issue.2, pp.73-86, 1996. ,
DOI : 10.1007/BF01214362
Recognition of shapes by editing their shock graphs, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.5, pp.550-571, 2002. ,
DOI : 10.1109/TPAMI.2004.1273924
Shape descriptors, " in Introduction to MPEG 7: Multimedia Content Description Language, pp.231-260, 2002. ,
