X-ray angiography in stereotactic conditions: techniques and interest for interventional neuroradiology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stereotactic and Functional Neurosurgery Année : 1997
L. Picard
  • Fonction : Auteur
Eric Maurincomme
M. Soderman
  • Fonction : Auteur
René Anxionnat
L. Launay
  • Fonction : Auteur
K. Ericson
  • Fonction : Auteur
S. Bracard
  • Fonction : Auteur
O. Flodmark
  • Fonction : Auteur
This paper reports work in progress on X-ray angiography acquired under stereotactic conditions. The objective is to be able to match multimodality images (typically MRI and X-ray) without a stereotactic frame but with stereotactic precision. We have identified potential problems and have studied them in detail. We conclude that, although the overall application is feasible, much work remains to be done on the estimation of the X-ray system conic projection and on automatic matching based on vascular structures.
Fichier non déposé
inria-00615078 , version 1 (17-08-2011)
L. Picard, Eric Maurincomme, M. Soderman, Jacques Feldmar, René Anxionnat, et al.. X-ray angiography in stereotactic conditions: techniques and interest for interventional neuroradiology. Stereotactic and Functional Neurosurgery, 1997, 68 (1-4 Pt 1), pp.117-20. ⟨10.1159/000099912⟩. ⟨inria-00615078⟩
111 Consultations
0 Téléchargements
