Journal articles
Using deformable surfaces to segment 3-D images and infer differential structures
Abstract : In this paper, we use a 3-D deformable model, which evolves in 3-D images, under the action of internal forces (describing some elasticity properties of the surface), and external forces attracting the surface toward some detected edgels. Our formalism leads to the minimization of an approach and a conforming finite element method to actually express the surface in e discrete basis of continuous functions. This leads to reduced computational complexity and better numerical stability. The power of the approach to segmenting 3-D images is demonstrated by a set of experimental results on various complex medical 3-D images. Another contribution of this approach is the possibility to infer easily the differential structure of the segmented surface. As we end up with an analytical description of class of the surface almost everywhere, this allows us to compute, for instance, its first and second fundamental forms. From this, one can extract a curvature primal sketch of the surface, including some intrinsic features which can be used as landmark for 3-D image interpretation?
Complete list of metadata
https://hal.inria.fr/inria-00615537
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Friday, August 19, 2011 - 4:44:48 PM
Last modification on : Tuesday, January 18, 2022 - 3:23:55 PM
Long-term archiving on: : Friday, November 25, 2011 - 11:36:21 AM
File
CohenCVGIPIU1992.pdf
Identifiers
Collections
Citation
Isaac Cohen, Laurent D. Cohen, Nicholas Ayache. Using deformable surfaces to segment 3-D images and infer differential structures. CVGIP: Image Understanding, Elsevier;Elsevier - Academic Press, 1992, 56 (2), pp.242--263. ⟨10.1016/1049-9660(92)90041-Z⟩. ⟨inria-00615537⟩
Share
Metrics
Record views
116
Files downloads
200
