Conference papers
Segmentation of Focal Cortical Dysplasia Lesions Using a Feature-Based Level Set
Abstract : Focal cortical dysplasia (FCD), a malformation of cortical development, is an important cause of medically intractable epilepsy. FCD lesions are difficult to distinguish from non-lesional cortex and their delineation on MRI is a challenging task. This paper presents a method to segment FCD lesions on T1-weighted MRI, based on a 3D deformable model, implemented using the level set framework. The deformable model is driven by three MRI features: cortical thickness, relative intensity and gradient. These features correspond to the visual characteristics of FCD and allow to differentiate lesions from normal tissues. The proposed method was tested on 18 patients with FCD and its performance was quantitatively evaluated by comparison with the manual tracings of two trained raters. The validation showed that the similarity between the level set segmentation and the manual labels is similar to the agreement between the two human raters. This new approach may become a useful tool for the presurgical evaluation of patients with intractable epilepsy.
Complete list of metadata
https://hal.inria.fr/inria-00616015
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Friday, August 19, 2011 - 6:22:14 PM
Last modification on : Friday, August 5, 2022 - 3:39:28 AM
Identifiers
Citation
Olivier Colliot, Tommaso Mansi, N. Bernasconi, V. Naessens, D. Klironomos, et al.. Segmentation of Focal Cortical Dysplasia Lesions Using a Feature-Based Level Set. Proc. Medical Image Computing and Computer Assisted Intervention (MICCAI'05), 2005, Palm Springs (CA), USA, United States. pp.375-382, ⟨10.1007/1156646547⟩. ⟨inria-00616015⟩
Share
Metrics
Record views
64
