A Log-Euclidean Polyaffine Framework for Locally Rigid or Affine Registration, WBIR. LNCS, pp.120-127, 2006. ,
DOI : 10.1007/11784012_15
URL : https://hal.archives-ouvertes.fr/inria-00615607
Iconic feature based nonrigid registration: the PASHA algorithm, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.272-298, 2003. ,
DOI : 10.1016/S1077-3142(03)00002-X
URL : https://hal.archives-ouvertes.fr/inria-00615633
The geometry of the newton method on non-compact lie groups, Journal of Global Optimization, vol.23, issue.3/4, pp.309-327, 2002. ,
DOI : 10.1023/A:1016586831090
Image registration results (two of the most accurate examples according to Table 1) The registered image (central column) is the moving image (left column) re-sampled in the geometry of the fixed image (right column). The slice numbers are 292 for the scan pair #9, and 157 for the scan pair #15 ,
Improving vision-based control using efficient second-order minimization techniques, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, 2004. ,
DOI : 10.1109/ROBOT.2004.1308092
Block Matching: A??General??Framework??to??Improve Robustness of??Rigid??Registration of Medical Images, MICCAI '00, pp.557-566, 2000. ,
DOI : 10.1007/978-3-540-40899-4_57
URL : https://hal.archives-ouvertes.fr/inria-00615860
Image matching as a diffusion process: an analogy with Maxwell's demons, Medical Image Analysis, vol.2, issue.3, pp.243-260, 1998. ,
DOI : 10.1016/S1361-8415(98)80022-4
Insight into Efficient Image Registration Techniques and the Demons Algorithm, IPMI '07, pp.495-506, 2007. ,
DOI : 10.1007/978-3-540-73273-0_41
URL : https://hal.archives-ouvertes.fr/inria-00165534
Diffeomorphic demons using itk's finite difference solver hierarchy, In: Insight Journal ? ISC Open Science at MICCAI, 2007. ,
Non-parametric Diffeomorphic Image Registration with the Demons Algorithm, MICCAI '07, pp.319-326, 2007. ,
DOI : 10.1007/978-3-540-75759-7_39
URL : https://hal.archives-ouvertes.fr/inria-00166123
