Automatic speech recognition and speech variability: A review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Speech Communication Année : 2007
Olivier Deroo
  • Fonction : Auteur
Stéphane Dupont
  • Fonction : Auteur
Denis Jouvet
Luciano Fissore
  • Fonction : Auteur
Christophe Ris
  • Fonction : Auteur
Richard Rose
  • Fonction : Auteur
Christian Wellekens
  • Fonction : Auteur
  • PersonId : 873362
Major progress is being recorded regularly on both the technology and exploitation of automatic speech recognition (ASR) and spoken language systems. However, there are still technological barriers to flexible solutions and user satisfaction under some circumstances. This is related to several factors, such as the sensitivity to the environment (background noise), or the weak representation of grammatical and semantic knowledge. Current research is also emphasizing deficiencies in dealing with variation naturally present in speech. For instance, the lack of robustness to foreign accents precludes the use by specific populations. Also, some applications, like directory assistance, particularly stress the core recognition technology due to the very high active vocabulary (application perplexity). There are actually many factors affecting the speech realization: regional, sociolinguistic, or related to the environment or the speaker herself. These create a wide range of variations that may not be modeled correctly (speaker, gender, speaking rate, vocal effort, regional accent, speaking style, non-stationarity, etc.), especially when resources for system training are scarce. This paper outlines current advances related to these topics.
inria-00616506 , version 1 (22-08-2011)
Mohamed Benzeghiba, Renato de Mori, Olivier Deroo, Stéphane Dupont, T. Erbes, et al.. Automatic speech recognition and speech variability: A review. Speech Communication, 2007, ⟨10.1016/j.specom.2007.02.006⟩. ⟨inria-00616506⟩
239 Consultations
0 Téléchargements
