Solving Cauchy problems by minimizing an energylike functional ,
URL : https://hal.archives-ouvertes.fr/hal-00139569
El Fekih On Cauchy's problem: II. Completion, regularization and approximation Inverse Problems, pp.1915-1936, 2006. ,
Orey On a Direct Study of an Operator Riccati Equation Appearing in Boundary Value Problems Factorization, Applied mathematical sciences, pp.46-2247, 2008. ,
A mixed formulation of quasi-reversibility to solve the Cauchy problem for Laplace's equation, Inverse Problems, vol.21, issue.3, pp.1087-1104, 2005. ,
DOI : 10.1088/0266-5611/21/3/018
Convergence rates for the quasi-reversibility method to solve the Cauchy problem for Laplace's equation, Inverse Problems, vol.22, issue.2, pp.413-430, 2006. ,
DOI : 10.1088/0266-5611/22/2/002
The method of quasi-reversibility to solve the Cauchy problems for elliptic partial differential equations, PAMM, vol.1, issue.1, pp.1042101-1042102, 2007. ,
DOI : 10.1002/pamm.200700001
Conditional stability for ill-posed elliptic Cauchy problems : the case of C1,1 domains (part I), 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00302354
Numerical simulation and optimal control in Plasma Physics with Application to Tokamaks, Modern Applied Mathematics), 1989. ,
Convergence analysis for finite element approximation to an inverse Cauchy problem, Inverse Problems, vol.22, issue.4 ,
DOI : 10.1088/0266-5611/22/4/005
Factorization of second-order elliptic boundary value problems by dynamic programming, Nonlinear Analysis, vol.59, issue.5, pp.629-647, 2004. ,
DOI : 10.1016/S0362-546X(04)00246-9
A Direct Study of the Riccati Equation Appearing in a Factorization Method of Second Order Elliptic Boundary Value Problems by Dynamic Programming Nonlinear Analysis, 2007. ,
A Computational Quasi-Reversibility Method for Cauchy Problems for Laplace???s Equation, SIAM Journal on Applied Mathematics, vol.51, issue.6, pp.1653-1675, 1991. ,
DOI : 10.1137/0151085
Méthode de Quasi-réversibilité et Applications, 1967. ,
Analytic extensions and Cauchy-type inverse problems on annular domains: stability results , J of Inverse Ill-Posed Problems, pp.189-204, 2006. ,
Controle optimal de systèmes gouvernés par deséquationsdeséquations aux dérivées partielles, 1968. ,
Tikhonov Regularization by a Reproducing Kernel Hilbert Space for the Cauchy Problem for an Elliptic Equation, SIAM Journal on Scientific Computing, vol.31, issue.1, pp.112-142, 2008. ,
DOI : 10.1137/070684793
