Formalization of Wu's simple method in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present in this paper the integration within the Coq proof assistant, of a method for automatic theorem proving in geometry. We use an approach based on the validation of a certificate. The certificate is generated by an implementation in Ocaml of a simple version of Wu's method.
document.pdf (383.53 Ko) Télécharger le fichier
inria-00618745 , version 1 (02-09-2011)
inria-00618745 , version 2 (20-09-2011)
Jean-David Génevaux, Julien Narboux, Pascal Schreck. Formalization of Wu's simple method in Coq. CPP 2011 First International Conference on Certified Programs and Proofs, Dec 2011, Kenting, Taiwan. pp.71-86, ⟨10.1007/978-3-642-25379-9_8⟩. ⟨inria-00618745v2⟩
Collections
CNRS
165 Consultations
628 Téléchargements
