New interface
Conference papers
Analysis of the Initial and Modified Versions of the Candidate 3GPP Integrity Algorithm 128-EIA3
Thomas Fuhr 1 Henri Gilbert 1 Jean-René Reinhard 1 Marion Videau 1, 2
2 CARAMEL - Cryptology, Arithmetic: Hardware and Software
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : In this paper we investigate the security of the two most recent versions of the message authentication code 128-EIA3, which is considered for adoption as a third integrity algorithm in the emerging 3GPP standard LTE. We first present an efficient existential forgery at- tack against the June 2010 version of the algorithm. This attack allows, given any message and the associated MAC value under an unknown integrity key and an initial vector, to predict the MAC value of a related message under the same key and the same initial vector with a success probability 1/2. We then briefly analyse the tweaked version of the al- gorithm that was introduced in January 2011 to circumvent this attack. We give some evidence that while this new version offers a provable re- sistance against similar forgery attacks under the assumption that (key, IV) pairs are never reused by any legitimate sender or receiver, some of its design features limit its resilience against IV reuse.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00619235
Contributor : Marion Videau Connect in order to contact the contributor
Submitted on : Wednesday, February 29, 2012 - 8:32:27 PM
Last modification on : Saturday, June 25, 2022 - 7:45:02 PM
Long-term archiving on: : Friday, November 23, 2012 - 4:11:26 PM
File
forgery.pdf
Identifiers
Collections
Citation
Thomas Fuhr, Henri Gilbert, Jean-René Reinhard, Marion Videau. Analysis of the Initial and Modified Versions of the Candidate 3GPP Integrity Algorithm 128-EIA3. 18th International Workshop on Selected Areas in Cryptography SAC 2011, Aug 2011, Toronto, Canada. pp.230-242, ⟨10.1007/978-3-642-28496-0⟩. ⟨inria-00619235⟩
Share
Metrics
Record views
342
Files downloads
371
