An introduction to observers, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.596-602, 1971. ,
DOI : 10.1109/TAC.1971.1099826
Joint state and parameter estimation for distributed mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.6-8, pp.659-677, 2008. ,
DOI : 10.1016/j.cma.2007.08.021
URL : https://hal.archives-ouvertes.fr/hal-00175623
A nudging-based data assimilation method: the Back and Forth Nudging (BFN) algorithm, Nonlinear Processes in Geophysics, vol.15, issue.2, pp.305-319, 2008. ,
DOI : 10.5194/npg-15-305-2008
URL : https://hal.archives-ouvertes.fr/inria-00327422
Recovering the initial state of an infinite-dimensional system using observers, Automatica, vol.46, issue.10, pp.1616-1625, 2010. ,
DOI : 10.1016/j.automatica.2010.06.032
URL : https://hal.archives-ouvertes.fr/hal-00529834
Uniform exponential long time decay for the space semidiscretization of a locally damped wave equation via an artificial numerical viscosity, Numerische Mathematik, vol.95, issue.3, pp.563-598, 2003. ,
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging, Inverse Problems, vol.25, issue.3, 2009. ,
DOI : 10.1088/0266-5611/25/3/035010
URL : https://hal.archives-ouvertes.fr/hal-00358914
Un exemple d'utilisation des notions de propagation pour le contrôlecontr?contrôle et la stabilisation desprobì emes hyperboliques, Hyperbolic Equations), pp.12-31, 1988. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, Applied Mathematical Sciences, vol.44, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
Locally Distributed Control and Damping for the Conservative Systems, SIAM Journal on Control and Optimization, vol.35, issue.5, pp.1574-1590, 1997. ,
DOI : 10.1137/S0363012995284928
Explicit observability estimate for the wave equation with potential and its application, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.456, issue.1997, pp.1101-1115, 1997. ,
DOI : 10.1098/rspa.2000.0553
Microlocal defect measures, Communications in Partial Differential Equations, vol.114, issue.11, pp.1761-1794, 1991. ,
DOI : 10.1080/03605308508820384
Mesures de d??faut de compacit??, application au syst??me de Lam??, Annales Scientifiques de l' ´ Ecole Normale Supérieure, pp.817-870, 2001. ,
DOI : 10.1016/S0012-9593(01)01078-3
Contrôle optimal deséquationsdes´deséquations aux derivées partielles, Cours de l'Ecole Polytechnique, 2002. ,
IMPROVING CONVERGENCE IN NUMERICAL ANALYSIS USING OBSERVERS ??? THE WAVE-LIKE EQUATION CASE, Mathematical Models and Methods in Applied Sciences ,
DOI : 10.1142/S0218202512500406
URL : https://hal.archives-ouvertes.fr/inria-00621052
Uniformly exponentially stable approximations for a class of damped systems, Journal de Math??matiques Pures et Appliqu??es, vol.91, issue.1, pp.20-48, 2009. ,
DOI : 10.1016/j.matpur.2008.09.002
URL : https://hal.archives-ouvertes.fr/hal-00681693
