Composabilité de codes parallèles sur architectures hétérogènes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Multicore machines equipped with accelerators are becoming increasingly popular in the High Performance Computing comunity. Due to the lack of consensus regarding the definition of a standard programming model for such machines, an increasing number of HPC developers are manually combining multiple programming environments to effectively use every underlying processing unit. In this document we present a framework which is able to dynamically alocate the computing ressources to the upper layers with great flexibility, in order to allow parallel applications to be seamlessly developed by composing existing parallel kernels.
Ahugo11Master.pdf (797.72 Ko) Télécharger le fichier
inria-00619654 , version 1 (06-09-2011)
  • HAL Id : inria-00619654 , version 1
Andra-Ecaterina Hugo. Composabilité de codes parallèles sur architectures hétérogènes. 2011. ⟨inria-00619654⟩
201 Consultations
171 Téléchargements
