Level lines based disocclusion, Proceedings 1998 International Conference on Image Processing. ICIP98 (Cat. No.98CB36269), pp.259-263, 2002. ,
DOI : 10.1109/ICIP.1998.999016
Fast Anisotropic Smoothing of Multi-Valued Images using Curvature-Preserving PDE's, International Journal of Computer Vision, vol.68, issue.1, pp.65-82, 2006. ,
DOI : 10.1007/s11263-006-5631-z
Region Filling and Object Removal by Exemplar-Based Image Inpainting, IEEE Transactions on Image Processing, vol.13, issue.9, pp.1200-1212, 2004. ,
DOI : 10.1109/TIP.2004.833105
Image Completion Using Efficient Belief Propagation Via Priority Scheduling and Dynamic Pruning, IEEE Transactions on Image Processing, vol.16, issue.11, pp.2649-2661, 2007. ,
DOI : 10.1109/TIP.2007.906269
Space-time completion of video, IEEE Trans. on PAMI, pp.463-476, 2007. ,
Image completion using structural priority belief propagation, Proceedings of the seventeen ACM international conference on Multimedia, MM '09, pp.717-720, 2009. ,
DOI : 10.1145/1631272.1631396
Texture synthesis by nonparametric sampling, IEEE ICCV, pp.1033-1038, 2002. ,
Stereoscopic inpainting: Joint color and depth completion from stereo images, 2008 IEEE Conference on Computer Vision and Pattern Recognition, pp.1-8, 2008. ,
DOI : 10.1109/CVPR.2008.4587704
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.171
Stereoscopic image inpainting illustrations (b) a stereoscopic image pair with the inpainting mask (in blue). (c) and (d) the inpainting results obtained using our method. (e) and (f) results obtained using [10]. (g) and (h) results obtained using ,
Stereoscopic Image Inpainting: Distinct Depth Maps and Images Inpainting, 2010 20th International Conference on Pattern Recognition, 2010. ,
DOI : 10.1109/ICPR.2010.997
URL : https://hal.archives-ouvertes.fr/hal-00551565
Multi-camera Scene Reconstruction via Graph Cuts, pp.8-40, 2002. ,
DOI : 10.1007/3-540-47977-5_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.8999
Mean shift: a robust approach toward feature space analysis, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.5, pp.603-619, 2002. ,
DOI : 10.1109/34.1000236
MLESAC: A New Robust Estimator with Application to Estimating Image Geometry, Computer Vision and Image Understanding, vol.78, issue.1, pp.138-156, 2000. ,
DOI : 10.1006/cviu.1999.0832
An Experimental Comparison of Min-cut/Max-flow Algorithms for Energy Minimization in Vision, IEEE Trans. on PAMI, vol.26, issue.9, pp.1124-1137, 2004. ,
DOI : 10.1007/3-540-44745-8_24
