Efficient maintenance techniques for views over active documents, Proceedings of the 12th International Conference on Extending Database Technology Advances in Database Technology, EDBT '09, 2009. ,
DOI : 10.1145/1516360.1516483
URL : https://hal.archives-ouvertes.fr/inria-00429637
Structural joins: a primitive for efficient XML query pattern matching, Proceedings 18th International Conference on Data Engineering, 2002. ,
DOI : 10.1109/ICDE.2002.994704
Tree pattern query minimization, The VLDB Journal The International Journal on Very Large Data Bases, vol.11, issue.4, 2002. ,
DOI : 10.1007/s00778-002-0076-7
XML access modules: Towards physical data independence in XML databases, 2005. ,
Algebra-Based Identification of Tree Patterns in XQuery, FQAS, 2006. ,
DOI : 10.1007/11766254_2
A Framework for Using Materialized XPath Views in XML Query Processing, VLDB, 2004. ,
DOI : 10.1016/B978-012088469-8.50009-7
Incremental validation of XML documents, ACM Transactions on Database Systems, vol.29, issue.4, 2004. ,
DOI : 10.1145/1042046.1042050
Update semantics of relational views, ACM Transactions on Database Systems, vol.6, issue.4, 1981. ,
DOI : 10.1145/319628.319634
Verification of Tree Updates for Optimization, CAV, 2005. ,
DOI : 10.1007/11513988_37
Schema-based independence analysis for XML updates, VLDB, 2009. ,
DOI : 10.14778/1687627.1687635
Destabilizers and independence of XML updates, VLDB, 2010. ,
DOI : 10.14778/1920841.1920956
Detecting XML query-update independence, Bases de Données Avancées, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00542526
Incremental XPath evaluation, ICDT, 2009. ,
Relational lenses, Proceedings of the twenty-fifth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '06, 2006. ,
DOI : 10.1145/1142351.1142399
An efficient XPath query processor for XML streams, ICDE, 2006. ,
Updating Recursive XML Views of Relations, J. Comput. Sci. Technol, vol.23, issue.4, 2008. ,
Order-Sensitive View Maintenance of Materialized XQuery Views, ER, 2003. ,
DOI : 10.1007/978-3-540-39648-2_14
Incremental Maintenance of Materialized XQuery Views, 22nd International Conference on Data Engineering (ICDE'06), 2006. ,
DOI : 10.1109/ICDE.2006.80
An algebraic approach to view maintenance for XQuery, PLAN-X workshop, 2008. ,
XPathMark: An XPath Benchmark for the XMark Generated Data, XSym, 2005. ,
DOI : 10.1007/11547273_10
Properties and update semantics of consistent views, ACM Transactions on Database Systems, vol.13, issue.4, 1988. ,
DOI : 10.1145/49346.50068
Maintaining views incrementally, SIGMOD, 1993. ,
Implementing data cubes efficiently, SIGMOD, 1996. ,
Efficient Processing of Expressive Node-Selecting Queries on XML Data in Secondary Storage, VLDB, 2003. ,
DOI : 10.1016/B978-012722442-8/50030-6
Query caching and view selection for XML databases, VLDB, 2005. ,
Efficient XQuery rewriting using multiple views, 2011 IEEE 27th International Conference on Data Engineering, 2011. ,
DOI : 10.1109/ICDE.2011.5767915
URL : https://hal.archives-ouvertes.fr/inria-00544366
XML materialized views in P2P. DataX workshop, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00431668
Incremental maintenance for materialized XPath/XSLT views, Proceedings of the 14th international conference on World Wide Web , WWW '05, 2005. ,
DOI : 10.1145/1060745.1060843
Rewriting nested XML queries using nested views, Proceedings of the 2006 ACM SIGMOD international conference on Management of data , SIGMOD '06, 2006. ,
DOI : 10.1145/1142473.1142524
Maintaining XPath views in loosely coupled systems, VLDB, 2006. ,
Incremental maintenance of path-expression views, Proceedings of the 2005 ACM SIGMOD international conference on Management of data , SIGMOD '05, 2005. ,
DOI : 10.1145/1066157.1066208
XMark, VLDB, 2002. ,
DOI : 10.1016/B978-155860869-6/50096-2
Multiple Materialized View Selection for XPath Query Rewriting, 2008 IEEE 24th International Conference on Data Engineering, 2008. ,
DOI : 10.1109/ICDE.2008.4497496
DDE, Proceedings of the 35th SIGMOD international conference on Management of data, SIGMOD '09, 2009. ,
DOI : 10.1145/1559845.1559921
Rewriting XPath queries using materialized views, VLDB, 2005. ,
