Parallel Copy Elimination on Data Dependence Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Register allocation regained much interest in recent years due to the development of decoupled strategies that split the problem into separate phases: spilling, register assignment, and copy elimination. Traditional approaches to copy elimination during register allocation are based on interference graphs and register coalescing. Variables are represented as nodes in a graph, which are coalesced, if they can be assigned the same register. However, decoupled approaches strive to avoid interference graphs and thus often resort to local recoloring. A common assumption of existing coalescing and recoloring approaches is that the original ordering of the instructions in the program is not changed. This work presents an extension of a local recoloring technique called Parallel Copy Motion. We perform code motion on data dependence graphs in order to eliminate useless copies and reorder instructions, while at the same time a valid register assignment is preserved. Our results show that even after traditional register allocation with coalescing our technique is able to eliminate an additional 3% (up to 9%) of the remaining copies and reduce the weighted costs of register copies by up to 25% for the SPECINT 2000 benchmarks. In comparison to Parallel Copy Motion, our technique removes 11% (up to 20%) more copies and up to 39% more of the copy costs.
RR-7735.pdf (523.47 Ko) Télécharger le fichier
inria-00625131 , version 1 (21-09-2011)
  • HAL Id : inria-00625131 , version 1
Florian Brandner, Quentin Colombet. Parallel Copy Elimination on Data Dependence Graphs. [Research Report] RR-7735, INRIA. 2011, pp.29. ⟨inria-00625131⟩
256 Consultations
166 Téléchargements
