Optimal spilling for CISC machines with few registers, Proc. of the Conf. on Programming Language Design and Implementation, PLDI '01, pp.243-253, 2001. ,
A Study of Spilling and Coalescing in Register Allocation as Two Separate Phases, 2009. ,
URL : https://hal.archives-ouvertes.fr/tel-00403504
Parallel copy motion, Proceedings of the 13th International Workshop on Software & Compilers for Embedded Systems, SCOPES '10, pp.1-110, 2010. ,
DOI : 10.1145/1811212.1811214
URL : https://hal.archives-ouvertes.fr/inria-00435844
On the Complexity of Register Coalescing, International Symposium on Code Generation and Optimization (CGO'07), pp.102-114, 2007. ,
DOI : 10.1109/CGO.2007.26
Register Spilling and Live-Range Splitting for SSA-Form Programs, Proc. of the Conf. on Compiler Construction , CC '09, pp.174-189, 2009. ,
DOI : 10.1007/978-3-642-00722-4_13
Preference-Guided Register Assignment, Proc. of the Conf. on Compiler Construction, CC '10, pp.205-223, 2010. ,
DOI : 10.1007/978-3-642-11970-5_12
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.454.212
Improvements to graph coloring register allocation, ACM Transactions on Programming Languages and Systems, vol.16, issue.3, pp.428-455, 1994. ,
DOI : 10.1145/177492.177575
An optimistic and conservative register assignment heuristic for chordal graphs, Proceedings of the 2007 international conference on Compilers, architecture, and synthesis for embedded systems , CASES '07, pp.209-217, 2007. ,
DOI : 10.1145/1289881.1289919
SSA-Based Register Allocation with PBQP, Proc. of the Conf. on Compiler Construction, pp.42-61, 2010. ,
DOI : 10.1145/1273442.1250746
Register allocation & spilling via graph coloring, Proc. of the Symposium on Compiler Construction, pp.98-105, 1982. ,
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, pp.451-490, 1991. ,
DOI : 10.1145/115372.115320
Code generator optimizations for the ST120 DSP-MCU core, Proceedings of the international conference on Compilers, architectures, and synthesis for embedded systems , CASES '00, pp.93-102, 2000. ,
DOI : 10.1145/354880.354894
Code Optimization for Digital Signal Processors, 2003. ,
Trace Scheduling: A Technique for Global Microcode Compaction, IEEE Transactions on Computers, vol.30, issue.7, pp.30478-490, 1981. ,
DOI : 10.1109/TC.1981.1675827
Iterated register coalescing, ACM Transactions on Programming Languages and Systems, vol.18, issue.3, pp.300-324, 1996. ,
DOI : 10.1145/229542.229546
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.4803
A Fast Cutting-Plane Algorithm for Optimal Coalescing, Proc. of the Conf. on Compiler Construction, CC'07, pp.111-125, 2007. ,
DOI : 10.1007/978-3-540-71229-9_8
Copy coalescing by graph recoloring, Proc. of the Conf. on Programming Language Design and Implementation, PLDI '08, pp.227-237, 2008. ,
Register Allocation for Programs in SSA-Form, Proc. of the Conf. on Compiler Construction, CC '06, pp.247-262, 2006. ,
DOI : 10.1007/11688839_20
The Superblock: An effective technique for VLIW and superscalar compilation, The Journal of Supercomputing, vol.7, issue.12, pp.229-248, 1993. ,
Optimistic register coalescing, ACM Transactions on Programming Languages and Systems, vol.26, issue.4, pp.735-765, 2004. ,
DOI : 10.1145/1011508.1011512
