Fault Tolerant Autonomic Computing Systems in a Chemical Setting - Archive ouverte HAL Access content directly
Book Sections Year : 2011
(1) , (1) , (1)
1
The chemical computing model was originally proposed as a simple and elegant parallel programming paradigm. Data are seen as molecules and computation as chemical reactions : if some molecules sat- isfy a predefined reaction condition, they are replaced by the product of the reaction. When no reaction is possible, a normal form is reached and the program terminates. In this paper, we describe how we can build fault tolerant autonomic systems in a chemical setting. We pay a partic- ular attention to the chemical description of the simple and successful constructs for fault-tolerance such as the recovery block scheme by de- signing a generic chemical framework. Then, we apply this framework to the development of an autonomic mailing system... all this in a chemical setting.
Not file
Dates and versions
inria-00625261 , version 1 (21-09-2011)
Identifiers
  • HAL Id : inria-00625261 , version 1
Cite
Jean-Pierre Banâtre, Christine Morin, Thierry Priol. Fault Tolerant Autonomic Computing Systems in a Chemical Setting. Jones, Cliff B.; Lloyd, John L. Dependable and Historic Computing, 6875, Springer, 2011, Lecture Notes in Computer Science, 978-3-642-24540-4. ⟨inria-00625261⟩
147 View
0 Download
Share
