Fault Tolerant Autonomic Computing Systems in a Chemical Setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
The chemical computing model was originally proposed as a simple and elegant parallel programming paradigm. Data are seen as molecules and computation as chemical reactions : if some molecules sat- isfy a predefined reaction condition, they are replaced by the product of the reaction. When no reaction is possible, a normal form is reached and the program terminates. In this paper, we describe how we can build fault tolerant autonomic systems in a chemical setting. We pay a partic- ular attention to the chemical description of the simple and successful constructs for fault-tolerance such as the recovery block scheme by de- signing a generic chemical framework. Then, we apply this framework to the development of an autonomic mailing system... all this in a chemical setting.
Fichier non déposé
inria-00625261 , version 1 (21-09-2011)
  • HAL Id : inria-00625261 , version 1
Jean-Pierre Banâtre, Christine Morin, Thierry Priol. Fault Tolerant Autonomic Computing Systems in a Chemical Setting. Jones, Cliff B.; Lloyd, John L. Dependable and Historic Computing, 6875, Springer, 2011, Lecture Notes in Computer Science, 978-3-642-24540-4. ⟨inria-00625261⟩
150 Consultations
0 Téléchargements
