Rate Coding Versus Temporal Order Coding: What the Retinal Ganglion Cells Tell the Visual Cortex, Neural Computation, vol.78, issue.6, pp.1255-1283, 2001. ,
DOI : 10.1016/0042-6989(96)00098-3
Spike arrival times: A highly efficient coding scheme for neural networks, Parallel Processing in Neural Systems and Computers, pp.91-94, 1990. ,
The Neural Code of the Retina, Neuron, vol.22, issue.3, pp.435-450, 1999. ,
DOI : 10.1016/S0896-6273(00)80700-X
Rapid Neural Coding in the Retina with Relative Spike Latencies, Science, vol.319, issue.5866, pp.1108-1111, 2008. ,
DOI : 10.1126/science.1149639
Speed of processing in the human visual system, Nature, vol.381, issue.6582, pp.520-522, 1996. ,
DOI : 10.1038/381520a0
Coding Static Natural Images Using Spiking Event Times: Do Neurons Cooperate?, IEEE Transactions on Neural Networks, vol.15, issue.5, pp.1164-1175, 2004. ,
DOI : 10.1109/TNN.2004.833303
URL : https://hal.archives-ouvertes.fr/hal-00110803
Biologically Inspired Means for Rank-Order Encoding Images: A Quantitative Analysis, IEEE Transactions on Neural Networks, vol.21, issue.7, pp.1087-1099, 2010. ,
DOI : 10.1109/TNN.2010.2048339
A novel bioinspired static image compression scheme for noisy data transmission over INRIA Frames for Exact Inversion of the Rank Order Coder 15 ,
Maximising information recovery from rank-order codes, Proceedings of SPIE, 2007. ,
A class of nonharmonic Fourier series, Transactions of the American Mathematical Society, vol.72, issue.2, pp.341-366 ,
DOI : 10.1090/S0002-9947-1952-0047179-6
An introduction to frames. Foundations and Trends in Signal Processing, 2008. ,
What Is the Goal of Sensory Coding?, Neural Computation, vol.21, issue.4, pp.559-601, 1994. ,
DOI : 10.1162/neco.1989.1.1.68
The Laplacian Pyramid as a Compact Image Code, IEEE Transactions on Communications, vol.31, issue.4, pp.532-540, 1983. ,
DOI : 10.1109/TCOM.1983.1095851
Error correction with frames: the Burt-Laplacian pyramid, IEEE Transactions on Information Theory, vol.41, issue.6, pp.2091-2093, 1995. ,
DOI : 10.1109/18.476342
Framing pyramids, IEEE Transactions on Signal Processing, vol.51, issue.9, pp.2329-2342, 2003. ,
DOI : 10.1109/TSP.2003.815389
A survey of out-of-core algorithms in numerical linear algebra, " in External Memory Algorithms and Visualization, pp.161-180, 1999. ,
