Stabilizing data-link over non-FIFO channels with optimal fault-resilience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Processing Letters Année : 2011
Self-stabilizing systems have the ability to converge to a correct behavior when started in any configuration. Most of the work done so far in the self-stabilization area assumed either communication via shared memory or via FIFO channels.This paper is the first to lay the bases for the design of self-stabilizing message passing algorithms over unreliable non-FIFO channels. We propose an optimal stabilizing data-link layer that emulates a reliable FIFO communication channel over unreliable capacity bounded non-FIFO channels (the channel capacity is known to the protocol).
inria-00627760 , version 1 (29-09-2011)
Shlomi Dolev, Swan Dubois, Maria Potop-Butucaru, Sébastien Tixeuil. Stabilizing data-link over non-FIFO channels with optimal fault-resilience. Information Processing Letters, 2011, 111 (18), pp.912-920. ⟨10.1016/j.ipl.2011.06.010⟩. ⟨inria-00627760⟩
135 Consultations
0 Téléchargements
