A probabilistic framework to infer brain functional connectivity from anatomical connections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel probabilistic framework to learn across several subjects a mapping from brain anatomical connectivity to functional connectivity, i.e. the covariance structure of brain activity. This prediction problem must be formulated as a structured-output learning task, as the predicted parameters are strongly correlated. We introduce a model selection framework based on cross-validation with a parametrization-independent loss function suitable to the manifold of covariance matrices. Our model is based on constraining the conditional independence structure of functional activity by the anatomical connectivity. Subsequently, we learn a linear predictor of a stationary multivariate autoregressive model. This natural parameterization of functional connectivity also enforces the positive-definiteness of the predicted covariance and thus matches the structure of the output space. Our results show that functional connectivity can be explained by anatomical connectivity on a rigorous statistical basis, and that a proper model of functional connectivity is essential to assess this link.
paper.pdf (731.44 Ko) Télécharger le fichier
inria-00627914 , version 1 (29-09-2011)
Fani Deligianni, Gaël Varoquaux, Bertrand Thirion, Emma Robinson, David J. Sharp, et al.. A probabilistic framework to infer brain functional connectivity from anatomical connections. Information Processing in Medical Imaging, Gábor Székely, Horst Hahn, Jul 2011, Kaufbeuren, Germany. pp.296-307, ⟨10.1007/978-3-642-22092-0_25⟩. ⟨inria-00627914⟩
472 Consultations
397 Téléchargements
