Joint T1 and Brain Fiber Diffeomorphic Registration Using the Demons
Non-linear image registration is one of the most challenging task in medical image analysis. In this work, we propose an extension of the well-established diffeomorphic Demons registration algorithm to take into account geometric constraints. Combining the deformation field induced by the image and the geometry, we define a mathematically sound framework to jointly register images and geometric descriptors such as fibers or sulcal lines. We demonstrate this framework by registering simultaneously T 1 images and 50 fiber bundles consistently extracted in 12 subjects. Results show the improvement of fibers alignment while maintaining, and sometimes improving image registration. Further comparisons with non-linear T 1 and tensor registration demonstrate the superiority of the Geometric Demons over their purely iconic counterparts.
Joint_T1_and_Brain_Fiber_Diffeomorphic_Registration_Using_the_Demons_.pdf (383.15 Ko)
Télécharger le fichier
Joint_T1_and_Brain_Fiber_Diffeomorphic_Registration_Using_the_Demons.odp (6.49 Mo)
Format : Autre
