Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, issue.4, pp.471-480, 1973. ,
DOI : 10.1109/TIT.1973.1055037
Recent results in the Shannon theory, IEEE Transactions on Information Theory, vol.20, issue.1, pp.2-10, 1974. ,
DOI : 10.1109/TIT.1974.1055171
An optimal distributed and adaptive source coding strategy using rate-compatible punctured convolutional codes, ICASSP, vol.3, pp.685-688, 2005. ,
Compression of correlated binary sources using turbo codes, IEEE Communications Letters, vol.5, issue.10, 2001. ,
DOI : 10.1109/4234.957380
Compression of binary sources with side information at the decoder using LDPC codes, IEEE Communications Letters, vol.6, issue.10, 2002. ,
DOI : 10.1109/LCOMM.2002.804244
Estimating distortion in a binary symmetric channel consistently, IEEE Transactions on Information Theory, vol.37, issue.5, 1991. ,
DOI : 10.1109/18.133270
On estimation for a binary-symmetric channel, IEEE Transactions on Information Theory, vol.44, issue.3, 1998. ,
DOI : 10.1109/18.669319
Distributed Parameter Estimation with Side Information: A Factor Graph Approach, 2007 IEEE International Symposium on Information Theory, 2007. ,
DOI : 10.1109/ISIT.2007.4557603
Correlation parameter estimation for LDPC-based slepian-wolf coding, IEEE Communications Letters, vol.13, issue.1, 2009. ,
DOI : 10.1109/LCOMM.2009.081247
Adaptive Slepian-Wolf decoding using particle filtering based belief propagation, 2009 47th Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.607-612, 2009. ,
DOI : 10.1109/ALLERTON.2009.5394914
Factor graphs and the sum-product algorithm, IEEE Transactions on Information Theory, vol.47, issue.2, 2001. ,
DOI : 10.1109/18.910572
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.54.1570
Fundamentals of statistical signal processing: estimation theory, 1993. ,
A tutorial on hidden Markov models and selected applications in speech recognition, Proc. IEEE, 1989. ,
Wyner???Ziv coding of video with unsupervised motion vector learning, Signal Processing: Image Communication, vol.23, issue.5, pp.369-378, 2008. ,
DOI : 10.1016/j.image.2008.04.009
