Multiple Point of Interest Discovery and Coverage with Mobile Wireless Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Milan Erdelj
Enrico Natalizio
Environmental monitoring has become a typical application of wireless sensor networks. The concept of monitoring certain Points of Interest (PoIs) instead of the whole sensor field helps reducing the costs of the deployment and improving the performance in terms of coverage. However, the problems of multiple PoI coverage, environment exploration and data report are still solved separately and there are no works that combine the aforementioned problems into a single deployment scheme. In this work, we present a novel approach for mobile sensor deployment, where we combine multiple PoI coverage with network connectivity preservation and environment exploration in order to capture the dynamics of the monitored area. We examine the performance of our scheme through extensive simulation campaigns.
Fichier non déposé
inria-00629216 , version 1 (05-10-2011)
  • HAL Id : inria-00629216 , version 1
Milan Erdelj, Enrico Natalizio, Tahiry Razafindralambo. Multiple Point of Interest Discovery and Coverage with Mobile Wireless Sensors. Workshop on Mobility and Communication for Cooperation and Coordination (MC3) at International Conference on Computing, Networking and Communications (ICNC 2012), Jan 2012, Maui, Hawaii, United States. ⟨inria-00629216⟩
Collections
INRIA INRIA2
103 Consultations
0 Téléchargements
