Optimal and robust control and estimation of linear paths to transition, Journal of Fluid Mechanics, vol.365, pp.305-349, 1998. ,
DOI : 10.1017/S0022112098001281
Visual Navigation for Mobile Robots: A Survey, Journal of Intelligent and Robotic Systems, vol.27, issue.1, pp.263-296, 2008. ,
DOI : 10.1007/s10846-008-9235-4
How to calculate dense piv vector fields at video rate, 8th Int. Symp. On Particle Image Velocimetry, 2009. ,
A new approach to visual servoing in robotics, IEEE Transactions on Robotics and Automation, vol.8, issue.3, pp.313-326, 1992. ,
DOI : 10.1109/70.143350
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.28, issue.4, pp.369-393, 2010. ,
DOI : 10.1007/s00348-009-0778-3
URL : https://hal.archives-ouvertes.fr/hal-00456162
A systems theory approach to the feedback stabilization of infinitesimal and finite-amplitude disturbances in plane Poiseuille flow, Journal of Fluid Mechanics, vol.24, pp.157-184, 1997. ,
DOI : 10.1017/S0022112087000892
Control of plane Poiseuille flow: a theoretical and computational investigation, 2006. ,
Accurate solution of the Orr???Sommerfeld stability equation, Journal of Fluid Mechanics, vol.45, issue.04, pp.689-703, 1971. ,
DOI : 10.1093/comjnl/4.4.318
Drag force in the open-loop control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.2, pp.810-826, 2002. ,
DOI : 10.1063/1.1432695
Robot control: the Task Function approach, 1991. ,
Fluid flows control using visual servoing, 18th IFAC World Congress, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00629595
A versatile camera calibration technique for high-accuracy 3D machine vision metrology using off-the-shelf TV cameras and lenses, IEEE Journal on Robotics and Automation, vol.3, issue.4, pp.323-344, 1987. ,
DOI : 10.1109/JRA.1987.1087109
