Dynamic power saving in fat-tree interconnection networks using on/off links, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639599
A survey of multicore processors, IEEE Signal Processing Magazine, vol.26, issue.6, pp.26-37, 2009. ,
DOI : 10.1109/MSP.2009.934110
A new theory of deadlock-free adaptive routing in wormhole networks, IEEE Trans. Parallel Distrib. Syst, pp.1320-1331, 1993. ,
Adaptive deadlock- and livelock-free routing with all minimal paths in torus networks, IEEE Transactions on Parallel and Distributed Systems, vol.5, issue.12, pp.1233-1251, 1994. ,
DOI : 10.1109/71.334898
Prevention of Deadlocks in Packet-Switched Data Transport Systems, IEEE Transactions on Communications, vol.29, issue.4, pp.512-524, 1981. ,
DOI : 10.1109/TCOM.1981.1095021
A 5-GHz Mesh Interconnect for a Teraflops Processor, IEEE Micro, vol.27, issue.5, pp.51-61, 2007. ,
DOI : 10.1109/MM.2007.4378783
Adaptive supply serial links with sub-1V operation and per-pin clock recovery, Proceedings of Int. Solid-State Circuits Conf, pp.1403-1413, 2002. ,
Application-aware deadlock-free oblivious routing, Proceedings of the 36th annual Int. Symp. on Computer architecture, pp.208-219, 2009. ,
DOI : 10.1145/1555815.1555782
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.4632
FinFET-based dynamic power management of onchip interconnection networks through adaptive back-gate biasing, Proceedings of ICCD 2009, the IEEE Int. Conf. on Computer Design, pp.350-357, 2009. ,
A variable frequency link for a power-aware network-on-chip (NoC), Integration, the VLSI Journal, vol.42, issue.4, pp.479-485, 2009. ,
DOI : 10.1016/j.vlsi.2009.01.002
Compiler-directed voltage scaling on communication links for reducing power consumption, ICCAD-2005. IEEE/ACM International Conference on Computer-Aided Design, 2005., pp.456-460, 2005. ,
DOI : 10.1109/ICCAD.2005.1560111
Power shifting in Thrifty Interconnection Network, 2011 IEEE 17th International Symposium on High Performance Computer Architecture, pp.156-167, 2011. ,
DOI : 10.1109/HPCA.2011.5749725
Analysis of application-aware on-chip routing under traffic uncertainty, Proceedings of the Fifth ACM/IEEE International Symposium on Networks-on-Chip, NOCS '11, pp.9-16, 2011. ,
DOI : 10.1145/1999946.1999949
Research Challenges for On-Chip Interconnection Networks, IEEE Micro, vol.27, issue.5, pp.96-108, 2007. ,
DOI : 10.1109/MM.2007.4378787
Source code for the simulations ,
Near-Optimal Worst-Case Throughput Routing for Two-Dimensional Mesh Networks, Proceedings of ISCA'05, the 32nd Int. Symp. on Computer Architecture, pp.432-443, 2005. ,
DOI : 10.1145/1080695.1070006
Dynamic voltage scaling with links for power optimization of interconnection networks, The Ninth International Symposium on High-Performance Computer Architecture, 2003. HPCA-9 2003. Proceedings., pp.91-102, 2003. ,
DOI : 10.1109/HPCA.2003.1183527
Power-aware communication optimization for networks-on-chips with voltage scalable links, Proceedings of the 2nd IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis , CODES+ISSS '04, pp.170-175, 2004. ,
DOI : 10.1145/1016720.1016763
