The generalized correlation method for estimation of time delay, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.24, issue.4, pp.320-327, 1976. ,
DOI : 10.1109/TASSP.1976.1162830
Blind Separation of Speech Mixtures via Time-Frequency Masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
DOI : 10.1109/TSP.2004.828896
Multiple emitter location and signal parameter estimation, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.276-280, 1986. ,
DOI : 10.1109/TAP.1986.1143830
Sparseness-Based 2CH BSS using the EM Algorithm in Reverberant Environment, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.147-150, 2007. ,
DOI : 10.1109/ASPAA.2007.4393015
Source localization in complex listening situations: Selection of binaural cues based on interaural coherence, The Journal of the Acoustical Society of America, vol.116, issue.5, pp.3075-3089, 2004. ,
DOI : 10.1121/1.1791872
On the use of spatial cues to improve binaural source separation, Proc. Int. Conf. on Digital Audio Effects (DAFx), pp.209-213, 2003. ,
A source localization/separation/respatialization system based on unsupervised classification of interaural cues, Proc. Int. Conf. on Digital Audio Effects (DAFx), pp.233-238, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00307889
Source number estimation and clustering for underdetermined blind source separation, Proc. 11th Int. Workshop on Acoustic Echo and Noise Control (IWAENC) ,
Grouping Separated Frequency Components by Estimating Propagation Model Parameters in Frequency-Domain Blind Source Separation, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.5, pp.1592-1604, 2007. ,
DOI : 10.1109/TASL.2007.899218
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.453.4393
An EM algorithm for localizing multiple sound sources in reverberant environments, Neural Information Processing Systems, pp.953-960, 2006. ,
Cumulative State Coherence Transform for a Robust Two-Channel Multiple Source Localization, Proc. 8th Int. Conf. on Independent Component Analysis and Signal Separation, pp.290-297, 2009. ,
DOI : 10.1016/S1566-2535(03)00003-4
Servì ere, A phase-based dual microphone method to count and locate audio sources in reverberant rooms, Proc. IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.209-212, 2009. ,
Localization of multiple sound sources with two microphones, The Journal of the Acoustical Society of America, vol.108, issue.4, pp.1888-1905, 2000. ,
DOI : 10.1121/1.1290516
Comparison Between Different Sound Source Localization Techniques Based on a Real Data Collection, 2008 Hands-Free Speech Communication and Microphone Arrays, pp.69-72, 2008. ,
DOI : 10.1109/HSCMA.2008.4538690
Comparison of different algorithms for acoustic source localization, in: ITG Fachtagung Sprachkommunikation, 2010. ,
Multi-source TDOA estimation using SNR-based angular spectra, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2616-2619, 2011. ,
DOI : 10.1109/ICASSP.2011.5947021
URL : https://hal.archives-ouvertes.fr/inria-00566706
A Robust Method to Count and Locate Audio Sources in a Multichannel Underdetermined Mixture, IEEE Transactions on Signal Processing, vol.58, issue.1, pp.121-133, 2010. ,
DOI : 10.1109/TSP.2009.2030854
URL : https://hal.archives-ouvertes.fr/inria-00489529
Temporal and time-frequency correlation-based blind source separation methods. Part I: Determined and underdetermined linear instantaneous mixtures, Signal Processing, vol.87, issue.3, pp.374-407, 2007. ,
DOI : 10.1016/j.sigpro.2006.05.012
URL : https://hal.archives-ouvertes.fr/hal-00270884
Identifying Single Source Data for Mixing Matrix Estimation in Instantaneous Blind Source Separation, Proc. 18th Int. Conf. on Artificial Neural Networks (ICANN), pp.759-767, 2008. ,
DOI : 10.1007/978-3-540-87536-9_78
Multichannel Nonnegative Matrix Factorization in Convolutive Mixtures for Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.550-563, 2010. ,
DOI : 10.1109/TASL.2009.2031510
Under-Determined Reverberant Audio Source Separation Using a Full-Rank Spatial Covariance Model, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1830-1840, 2010. ,
DOI : 10.1109/TASL.2010.2050716
URL : https://hal.archives-ouvertes.fr/inria-00435807
Adaptive Segmentation and Separation of Determined Convolutive Mixtures under Dynamic Conditions, Proc. 9th Int. Conf. on Latent Variable Analysis and Signal Separation, pp.41-48, 2010. ,
DOI : 10.1007/978-3-642-15995-4_6
Underdetermined Instantaneous Audio Source Separation via Local Gaussian Modeling, Proc. 8th Int. Conf. on Independent Component Analysis and Blind Source Separation, pp.775-782, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00482223
Blind Spectral-GMM Estimation for Underdetermined Instantaneous Audio Source Separation, Proc. 8th Int. Conf. on Independent Component Analysis and Blind Source Separation, pp.751-758, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00482287
Speech segregation based on sound localization, The Journal of the Acoustical Society of America, vol.114, issue.4, pp.2236-2252, 2003. ,
DOI : 10.1121/1.1610463
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.5314
Two decades of array signal processing research: the parametric approach, IEEE Signal Processing Magazine, vol.13, issue.4, pp.67-94, 1996. ,
DOI : 10.1109/79.526899
Stereo Source Separation and Source Counting with MAP Estimation with Dirichlet Prior Considering Spatial Aliasing Problem, Proc. 8th Int. Conf. on Independent Component Analysis and Blind Source Separation, pp.742-750, 2009. ,
DOI : 10.1007/978-3-540-30110-3_55
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.466.1137
Maximum likelihood from incomplete data via the EM algorithm, Journal of the Royal Statistical Society. Series B (Methodological), vol.39, issue.1, pp.1-38, 1977. ,
The 2008 Signal Separation Evaluation Campaign: A Community-Based Approach to Large-Scale Evaluation, Proc. 8th Int. Conf. on Independent Component Analysis and Signal Separation, pp.734-741, 2009. ,
DOI : 10.1109/TASL.2007.899176
URL : https://hal.archives-ouvertes.fr/inria-00544168
Information retrieval, 1979. ,
