The Numerical Integration of Two-Point Boundary Value Problems, Mathematical Tables and Other Aids to Computation, vol.10, issue.54, pp.82-86, 1956. ,
DOI : 10.2307/2002181
Multiple shooting method for two-point boundary value problems, Communications of the ACM, vol.5, issue.12, pp.613-614, 1962. ,
DOI : 10.1145/355580.369128
Numerical methods for two-point boundary-value problems, 1968. ,
Die mehrzielmethode zur numerischen lösung von nichtlinearen randwertproblemen und aufgaben der optimalen steuerung, Deutsches Zentrum für Luft-und Raumfahrt (DLR), 1971. ,
Numerical solution of singular control problems using multiple shooting techniques, Journal of Optimization Theory and Applications, vol.8, issue.2, pp.235-257, 1976. ,
DOI : 10.1007/BF00935706
Numerische Behandlung singulärer Steuerungen mit der Mehrzielmethode am Beispiel der Klimatisierung von Sonnenhäusern, 1977. ,
Numerical computation of singular control problems with application to optimal heating and cooling by solar energy, Applied Mathematics & Optimization, vol.5, issue.1, pp.297-314, 1979. ,
DOI : 10.1007/BF01442560
Finding candidate singular optimal controls: A state of the art survey, Journal of Optimization Theory and Applications, vol.1, issue.2, pp.173-190, 1989. ,
DOI : 10.1007/BF00940004
Numerical resolution of optimal control problems by a piecewise linear continuation method, 2005. ,
Switching Time Optimization for Bang-Bang and??Singular??Controls, Journal of Optimization Theory and Applications, vol.13, issue.1, pp.409-429, 2010. ,
DOI : 10.1007/s10957-009-9594-4
Partially affine control problems: second order conditions and a well-posed shooting algorithm, INRIA Research Rapport Nr, vol.7764, 2011. ,
Théorie des singularités de l'application entrée/sortie et optimalité des trajectoiressingulì eres dans leprobì eme du temps minimal, Forum Math, vol.5, issue.2, pp.111-159, 1993. ,
Second order optimality conditions in the smooth case and applications in optimal control, ESAIM: Control, Optimisation and Calculus of Variations, vol.13, issue.2, pp.207-236, 2007. ,
DOI : 10.1051/cocv:2007012
URL : https://hal.archives-ouvertes.fr/hal-00086380
Singular trajectories and their role in control theory, of Mathématiques & Applications (Berlin) [Mathematics & Applications, 2003. ,
Sensitivity analysis for parametric control problems with control-state constraints, Proceedings of 1994 33rd IEEE Conference on Decision and Control, pp.253-283, 1996. ,
DOI : 10.1109/CDC.1994.410938
Revisiting the analysis of optimal control problems with several state constraints, Control Cybernet, vol.38, issue.4A, pp.1021-1052, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00778363
Nonlinear least-squares The State of the Art in Numerical Analysis, pp.269-312, 1977. ,
Practical methods of optimization, 1980. ,
DOI : 10.1002/9781118723203
An Adaptive Nonlinear Least-Squares Algorithm, ACM Transactions on Mathematical Software, vol.7, issue.3, pp.348-368, 1981. ,
DOI : 10.1145/355958.355965
Quadratic conditions for a weak minimum for singular regimes in optimal control problems, Soviet Math. Doklady, vol.18, issue.2, 1977. ,
QUADRATIC CONDITIONS FOR A PONTRYAGIN MINIMUM IN AN OPTIMUM CONTROL PROBLEM LINEAR IN THE CONTROL. I: A DECODING THEOREM, Mathematics of the USSR-Izvestiya, vol.28, issue.2, pp.275-303, 1987. ,
DOI : 10.1070/IM1987v028n02ABEH000882
Structural Stability Investigation of Bang-Singular-Bang Optimal Controls, Journal of Optimization Theory and Applications, vol.59, issue.1, 2011. ,
DOI : 10.1007/s10957-011-9925-0
Controllability and stability for problems with bangsingular-bang optimal control, 2011. ,
3 Singular Extremals, Topics in Optimization, pp.63-101, 1967. ,
DOI : 10.1016/S0076-5392(09)60039-4
A second variation test for singular extremals, AIAA Journal, vol.2, issue.8, pp.1380-1382, 1964. ,
DOI : 10.2514/3.2562
Necessary Conditions for Singular Extremals Involving Multiple Control Variables, SIAM Journal on Control, vol.4, issue.4, pp.716-731, 1966. ,
DOI : 10.1137/0304052
Osmolovski? ?. Higher order conditions for local minima in problems with constraints, Uspekhi Mat. Nauk, vol.33, issue.272, pp.85-148, 1978. ,
The Second Variation for the Singular Bolza Problem, SIAM Journal on Control, vol.4, issue.2, pp.309-325, 1966. ,
DOI : 10.1137/0304026
Quadratic conditions for bang-singular extremals. Numerical Algebra, Control and Optimization, special issue in honor of Helmut Maurer, and ,
URL : https://hal.archives-ouvertes.fr/inria-00605128
Sufficiency Criteria via Focal Points and via Coupled Points, SIAM Journal on Control and Optimization, vol.30, issue.1, pp.82-98, 1992. ,
DOI : 10.1137/0330006
Study of an Optimum Non-linear Control System???, Journal of Electronics and Control, vol.15, issue.1, pp.63-71, 1963. ,
DOI : 10.1080/00207216308937555
Survey of Numerical Methods for Trajectory Optimization, Journal of Guidance, Control, and Dynamics, vol.21, issue.2, pp.193-207, 1998. ,
DOI : 10.2514/2.4231
Nonlinear programming, Concepts, algorithms, and applications to chemical processes, 2010. ,
DOI : 10.1137/1.9780898719383
An application of PL continuation methods to singular arcs problems, Recent Advances in Optimization, pp.163-186, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00974849
Singular arcs in the generalized Goddard's problem, J. Optim. Theory Appl, vol.139, issue.2, pp.439-461, 2008. ,
Mathematical Bioeconomics, 1976. ,
DOI : 10.1007/978-3-642-45455-4_3
The computation of optimal singular control, International Journal of Control, vol.11, issue.5, pp.681-688, 1978. ,
DOI : 10.1080/00207177808922489
A Method of Reaching Extreme Altitudes, Smithsonian Miscellaneous Collections. Smithsonian institution, vol.71, issue.2, 1919. ,
Goddard problem in presence of a dynamic pressure limit, Journal of Guidance, Control, and Dynamics, vol.16, issue.4, pp.776-781, 1993. ,
DOI : 10.2514/3.21080
0: An indirect grid shooting package for optimal control problems, with switching handling and embedded continuation, pp.2011-7380 ,
URL : https://hal.archives-ouvertes.fr/inria-00517515
User Guide for Minpack-1. National Argonne Laboratory, Illinois, des Vignes 4, rue Jacques Monod -91893 Orsay Cedex, 1980. ,
