Sobolev spaces, 1975. ,
An Algorithm for Abstract Optimal Control Problems Using Maximum Principles and Applications to a Class of Distributed Parameter Systems, Optimal control Internat. Ser. Numer. Math, vol.11195, pp.31-42, 1991. ,
DOI : 10.1007/978-3-0348-7539-4_3
Second order analysis for control constrained optimal control problems of semilinear elliptic systems Pontryagin's principle for the optimal control of semilinear elliptic systems with state constraints, Proceedings of the 30th Conference on Decision and Control, pp.38-41, 1991. ,
On an Algorithm for Optimal Control Using Pontryagin???s Maximum Principle, SIAM Journal on Control and Optimization, vol.24, issue.3, pp.579-588, 1986. ,
DOI : 10.1137/0324034
Un principe de Pontryagine pour le contr??le des syst??mes semilin??aires elliptiques, Journal of Differential Equations, vol.90, issue.2, pp.288-303, 1989. ,
DOI : 10.1016/0022-0396(91)90149-4
Osmolovski? ?, Second-order analysis of optimal control problems with control and initial-final state constraints Characterization of a local quadratic growth of the hamiltonian for control constrained optimal control problems, Journal of Convex Analysis Dynamics of Continuous, Discrete and Impulsive Systems, vol.17, issue.19, pp.885-913, 2010. ,
Perturbation analysis of optimization problems, 2000. ,
DOI : 10.1007/978-1-4612-1394-9
Asymptotic Expansion for the Solutions of Control Constrained Semilinear Elliptic Problems with Interior Penalties, SIAM Journal on Control and Optimization, vol.49, issue.6, pp.2494-2517, 2011. ,
DOI : 10.1137/090778602
Optimal Control Problems with Partially Polyhedric Constraints, SIAM Journal on Control and Optimization, vol.37, issue.6, pp.1726-1741, 1999. ,
DOI : 10.1137/S0363012998333724
URL : https://hal.archives-ouvertes.fr/inria-00073340
Sufficient Second-Order Optimality Conditions for Semilinear Control Problems with Pointwise State Constraints, SIAM Journal on Optimization, vol.19, issue.2, pp.19-21, 2008. ,
DOI : 10.1137/07068240X
Second-Order Necessary Optimality Conditions for Some State-Constrained Control Problems of Semilinear Elliptic Equations, Applied Mathematics and Optimization, vol.39, issue.2, pp.211-228, 1999. ,
DOI : 10.1007/s002459900104
Second order sufficient optimality conditions for a nonlinear elliptic control problem Second order sufficient optimality conditions for some state-constrained control problems of semilinear elliptic equations, Journal for Analysis and its Applications SIAM J. Control Optim, vol.15, issue.38, pp.687-707, 1996. ,
Partial differential equations, Amer, Graduate Studies in Mathematics CHARACTERIZATION OF STRONG MINIMA IN THE OPTIMAL CONTROL OF PDES, vol.19, p.25, 1998. ,
Optimal control of distributed systems, theory and applications, Translations of Mathematical Monographs, vol.187, 1999. ,
Elliptic partial differential equations of second order, 1983. ,
How to differentiate the projection on a convex set in Hilbert space. Some applications to variational inequalities, Journal of the Mathematical Society of Japan, vol.29, issue.4, pp.615-631, 1977. ,
DOI : 10.2969/jmsj/02940615
On approximate solutions of systems of linear inequalities, Journal of Research of the National Bureau of Standards, Section B, Mathematical Sciences, vol.49, pp.263-265, 1952. ,
Optimal control theory for infinite dimensional systems, Systems and Control: Foundations and Applications, 1994. ,
DOI : 10.1007/978-1-4612-4260-4
Contrôle dans les inéquations variationnelles, Journal of Functional Analysis, vol.22, pp.25-39, 1976. ,
Osmolovski? ?, Calculus of variations and optimal control, Systems and Control: Foundations and Applications, 1998. ,
The mathematical theory of optimal processes, pp.35848250-10943, 1962. ,
The maximum principle in optimal control problems for an elliptic equation (in Russian), Zeitschrift f??r Analysis und ihre Anwendungen, vol.5, issue.4, pp.291-306, 1986. ,
DOI : 10.4171/ZAA/200
Integral functionals, normal integrands and measurable selections, Lecture Notes in Math, vol.159, issue.2, pp.157-207, 1975. ,
DOI : 10.1090/S0002-9947-1971-0282283-0
Sufficient Second???Order Optimality Conditions for an Elliptic Optimal Control Problem with Pointwise Control???State Constraints, SIAM Journal on Optimization, vol.17, issue.3, pp.17-20, 2006. ,
DOI : 10.1137/050625850
Le probl??me de Dirichlet pour les ??quations elliptiques du second ordre ?? coefficients discontinus, Annales de l???institut Fourier, vol.15, issue.1, pp.189-258, 1965. ,
DOI : 10.5802/aif.204
Optimal Control of Partial Differential Equations -Theory, Methods and Applications, Graduate Studies in Mathematics, vol.112, 2010. ,
