A survey of autonomic computing???degrees, models, and applications, ACM Computing Surveys, vol.40, issue.3, pp.1-728, 2008. ,
DOI : 10.1145/1380584.1380585
How Dynamic is the Grid? Towards a Quality Metric for Grid Information Systems, 11th IEEE/ACM Int. Conf. on Grid Computing, pp.113-120, 2010. ,
Julien Nauroy, Michèle Sebag. The Grid Observatory, 11th IEEE/ACM International Symposium on Cluster, Cloud, and Grid Computing, 2011. ,
Analysis and modeling of job arrivals in a production grid, ACM SIGMETRICS Performance Evaluation Review, vol.34, issue.4, pp.59-70, 2007. ,
DOI : 10.1145/1243401.1243402
Modeling the latency on production grids with respect to the execution context, Parallel Computing, vol.35, pp.493-511, 2009. ,
A Realistic Integrated Model of Parallel System Workloads, 2010 10th IEEE/ACM International Conference on Cluster, Cloud and Grid Computing, pp.464-473, 2010. ,
DOI : 10.1109/CCGRID.2010.32
Occasional structural breaks and long memory with an application to the S&P 500 absolute stock returns, J. Empirical Finance, vol.11, issue.3, pp.399-421, 2004. ,
The Hurst effect under trends, J. Appl. Probab, vol.20, issue.3, pp.649-662, 1983. ,
Exact Bayesian curve fitting and signal segmentation, IEEE Trans. Signal Process, vol.53, issue.6, pp.2160-2166, 2005. ,
Eliciting honest value information in a batch-queue environment, 2007 8th IEEE/ACM International Conference on Grid Computing, pp.291-297, 2007. ,
DOI : 10.1109/GRID.2007.4354145
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.547.2319
Discovering Piecewise Linear Models of Grid Workload Cloud and Grid Computing, pp 474?484 Structural break estimation for nonstationary time series models, Hansen et al. Reducing the Time Complexity of the Derandomized Evolution Strategy with Covariance Matrix Adaptation (CMA?ES). Evolutionary Computation, pp.229-2391, 2003. ,
Regression and time series model selection in small samples Bagging binary and quantile predictors for times series, Biometrika J. of Econometrics, vol.76, issue.21?2, pp.297-307, 1989. ,
Toward Autonomic Grids: Analyzing the Job Flow with Affinity Streaming, 15th ACM Conf. on Knowledge Discovery and Data Mining, pp.987-996, 2009. ,
