On the Roth and Ruckenstein equations for the Guruswami-Sudan algorithm, 2008 IEEE International Symposium on Information Theory, pp.2620-2624, 2008. ,
DOI : 10.1109/ISIT.2008.4595466
URL : https://hal.archives-ouvertes.fr/inria-00509209
Efficient list-decoding of Reed-Solomon codes with the Fundamental Iterative Algorithm, 2009 IEEE Information Theory Workshop, 2009. ,
DOI : 10.1109/ITW.2009.5351241
URL : https://hal.archives-ouvertes.fr/hal-00647592
Improved decoding of Reed-Solomon and algebraic-geometry codes, IEEE Transactions on Information Theory, vol.45, issue.6, pp.1757-1767, 1999. ,
DOI : 10.1109/18.782097
List Decoding of Error-Correcting Codes, ser. Lecture Notes in Computer Science, 2004. ,
Decoding of Reed Solomon Codes beyond the Error-Correction Bound, Journal of Complexity, vol.13, issue.1, pp.180-193, 1997. ,
DOI : 10.1006/jcom.1997.0439
Polynomial Codes Over Certain Finite Fields, Journal of the Society for Industrial and Applied Mathematics, vol.8, issue.2, pp.300-304, 1960. ,
DOI : 10.1137/0108018
On Algebraic Decoding of Algebraic-Geometric and Cyclic Codes, 1996. ,
Efficient Decoding of Reed?Solomon Codes Beyond Half the Minimum Distance Information Theory, IEEE Transactions on, vol.46, issue.1, pp.246-257, 2000. ,
Error Decoding Strategies for Algebraic Codes, 2001. ,
Linear Diophantine Equations Over Polynomials and Soft Decoding of Reed-Solomon Codes Information Theory, IEEE Transactions on, vol.51, issue.7, pp.2257-2265, 2005. ,
Efficient Interpolation in the Guruswami?Sudan Algorithm Information Theory, IEEE Transactions on, vol.56, issue.9, pp.4341-4349, 2010. ,
Finding a minimal polynomial vector set of a vector of nD arrays, Proceedings of Applied Algebra, Algebraic Algorithms and Error?Correcting Codes (AAECC '91), ser. LNCS, H. F ,
DOI : 10.1007/3-540-54522-0_129
A Generalization of the Berlekamp- Massey Algorithm for Multisequence Shift-Register Synthesis with Applications to Decoding Cyclic Codes Information Theory, IEEE Transactions on, vol.37, issue.5, pp.1274-1287, 1991. ,
Algebraic coding theory, 1968. ,
DOI : 10.1142/9407
Shift-Register Synthesis and BCH Decoding Information Theory, IEEE Transactions on, vol.15, issue.1, pp.122-127, 2003. ,
DOI : 10.1109/tit.1969.1054260
A Syndrome Formulation of the Interpolation Step in the Guruswami-Sudan Algorithm, " in ICMCTA, ser. Lecture Notes in Computer Science, A. I. Barbero, pp.20-32, 2008. ,
Key equations for list decoding of Reed???Solomon codes and how to solve them, Journal of Symbolic Computation, vol.45, issue.7, pp.773-786, 2010. ,
DOI : 10.1016/j.jsc.2010.03.010
Error correction of algebraic block codes, US Patent Number, vol.4633, p.470 ,
The Theory of Error-Correcting Codes (North-Holland Mathematical Library), 1988. ,
Introduction to Coding Theory, 2006. ,
DOI : 10.1017/CBO9780511808968
Theorie der höheren Differentiale in einem algebraischen Funktionenkörper mit vollkommenem Konstantenkörper bei beliebiger Charakteristik, J. Reine Angew. Math, vol.175, pp.50-54, 1936. ,
Highly resilient correctors for polynomials, Information Processing Letters, vol.43, issue.4, pp.169-174, 1992. ,
DOI : 10.1016/0020-0190(92)90195-2
Two new decoding algorithms for Reed- Solomon codes Applicable Algebra in Engineering, Communication and Computing, vol.5, issue.1, pp.23-43, 1994. ,
Fast parallel algorithms for decoding Reed-Solomon codes based on remainder polynomials Information Theory, IEEE Transactions on, vol.41, issue.4, pp.873-885, 1995. ,
A Course in Error-Correcting Codes (EMS Textbooks in Mathematics), 2004. ,
A method for solving key equation for decoding goppa codes, Information and Control, vol.27, issue.1, pp.87-99, 1975. ,
DOI : 10.1016/S0019-9958(75)90090-X
On the Equivalence Between Berlekamp's and Euclid's Algorithms Information Theory, IEEE Transactions on, vol.33, issue.3, pp.428-431, 1987. ,
On the Equivalence of the Berlekamp-Massey and the Euclidean Algorithms for Decoding Information Theory Available: http://dx.doi.org/10 From the Euclidean Algorithm for Solving a Key Equation for Dual Reed?Solomon Codes to the Berlekamp?Massey Algorithm, AAECC, ser. Lecture Notes in Computer Science, M. Bras-Amorós and T. Høholdt, pp.2614-2624, 1109. ,
Collaborative Decoding of Interleaved Reed-Solomon Codes and Concatenated Code Designs Information Theory, IEEE Transactions on, vol.55, issue.7, pp.2991-3012, 2009. ,
The Guruswami?Sudan Decoding Algorithm for Reed?Solomon Codes, Interplanetary Network Progress Report, vol.153, pp.1-6042, 2003. ,
The Decoding of Algebraic Geometry Codes, Series on Coding Theory and Cryptology : Advances in Algebraic Geometry Codes, pp.49-98, 2008. ,
DOI : 10.1142/9789812794017_0002
His major research interests are coding theory, cryptography and their interplay ,
