Improved Collision-Correlation Power Analysis on First Order Protected AES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christophe Clavier
DMI
Benoit Feix
  • Fonction : Auteur
  • PersonId : 883791
DMI
Georges Gagnerot
  • Fonction : Auteur
  • PersonId : 918159
DMI
Mylène Roussellet
  • Fonction : Auteur
  • PersonId : 883792
The recent results presented by Moradi et al. on AES at CHES 2010 and Witteman et al. on square-and-multiply always RSA exponentiation at CT-RSA 2011 have shown that collision-correlation power analysis is able to recover the secret keys on embedded implementations. However, we noticed that the attack published last year by Moradi et al. is not efficient on correctly first-order protected implementations. We propose in this paper improvements on collision-correlation attacks which require less power traces than classical second-order power analysis techniques. We present here two new methods and show in practice their real efficiency on two first-order protected AES implementations. We also mention that other symmetric embedded algorithms can be targeted by our new techniques.
CFGRV11_CollisionAES.pdf (481.86 Ko) Télécharger le fichier
inria-00633527 , version 1 (27-10-2011)
Christophe Clavier, Benoit Feix, Georges Gagnerot, Mylène Roussellet, Vincent Verneuil. Improved Collision-Correlation Power Analysis on First Order Protected AES. Workshop on Cryptographic Hardware and Embedded Systems - CHES 2011, Sep 2011, Nara, Japan. pp.49-62, ⟨10.1007/978-3-642-23951-9_4⟩. ⟨inria-00633527⟩
399 Consultations
841 Téléchargements
