Numerical simulation of the general dynamic equation (GDE) for aerosols with two collocation methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Numerical Mathematics Année : 2007
This paper presents two algorithms for solving the general dynamic equation for aerosols. Coagulation and condensation are solved simultaneously without using splitting. The first method is based on a collocation method for size discretization and a Rosenbrock solver for time integration. In the second method, time discretization is first performed. This leads to a Volterra equation of first kind, which is solved with cubic splines. Both methods are compared to a reference solution for constant coagulation and linear condensation.
inria-00633766 , version 1 (19-10-2011)
Edouard Debry, Bruno Sportisse. Numerical simulation of the general dynamic equation (GDE) for aerosols with two collocation methods. Applied Numerical Mathematics, 2007, 57 (8), pp.885-898. ⟨10.1016/j.apnum.2006.08.002⟩. ⟨inria-00633766⟩
122 Consultations
0 Téléchargements
