The composite absolute penalties family for grouped and hierarchical variable selection, The Annals of Statistics, vol.37, issue.6A, pp.3468-3497, 2009. ,
DOI : 10.1214/07-AOS584
Structured variable selection with sparsity-inducing norms, tech. rep, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00377732
Group lasso with overlap and graph lasso, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553431
Learning with structured sparsity, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553429
Model-Based Compressive Sensing, IEEE Transactions on Information Theory, vol.56, issue.4, pp.1982-2001, 2010. ,
DOI : 10.1109/TIT.2010.2040894
Sparse signal recovery using Markov random fields, [Advances in Neural Information Processing Systems, 2008. ,
Exploiting structure in wavelet-based Bayesian compressive sensing, IEEE Transactions on Signal Processing, vol.57, issue.9, pp.3488-3497, 2009. ,
Simultaneous Variable Selection, Technometrics, vol.47, issue.3, pp.349-363, 2005. ,
DOI : 10.1198/004017005000000139
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
Joint covariate selection and joint subspace selection for multiple classification problems, Statistics and Computing, vol.8, issue.68, pp.231-252, 2010. ,
DOI : 10.1007/s11222-008-9111-x
Proximal methods for hierarchical sparse coding, Journal of Machine Learning Research, vol.12, pp.2297-2334, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00516723
Network flow algorithms for structured sparsity, [Advances in Neural Information Processing Systems, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00512556
Convex and network flow optimization for structured sparsity, " accepted with minor revision in the, preprint arXiv, pp.1104-1872, 2011. ,
Sparse coding with an overcomplete basis set: A strategy employed by V1?, Vision Research, vol.37, issue.23, pp.3311-3325, 1997. ,
DOI : 10.1016/S0042-6989(97)00169-7
Emergence of simple-cell receptive field properties by learning a sparse code for natural images, Nature, vol.381, issue.6583, pp.607-609, 1996. ,
DOI : 10.1038/381607a0
Frame based signal compression using method of optimal directions (MOD), ISCAS'99. Proceedings of the 1999 IEEE International Symposium on Circuits and Systems VLSI (Cat. No.99CH36349), p.4, 1999. ,
DOI : 10.1109/ISCAS.1999.779928
Image Denoising Via Sparse and Redundant Representations Over Learned Dictionaries, IEEE Transactions on Image Processing, vol.15, issue.12, pp.3736-3745, 2006. ,
DOI : 10.1109/TIP.2006.881969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6477
Online learning for matrix factorization and sparse coding, Journal of Machine Learning Research, vol.11, pp.19-60, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00408716
Sparse Representation for Color Image Restoration, IEEE Transactions on Image Processing, vol.17, issue.1, pp.53-69, 2008. ,
DOI : 10.1109/TIP.2007.911828
Learning invariant features through topographic filter maps, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206545
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.9635
Topographic Independent Component Analysis, Neural Computation, vol.18, issue.10, pp.1527-1558, 2001. ,
DOI : 10.1016/S0013-4694(97)00042-8
singularities, Communications on Pure and Applied Mathematics, vol.9, issue.7, pp.219-266, 2004. ,
DOI : 10.1002/cpa.10116
Wedgelets: nearly minimax estimation of edges, The Annals of Statistics, vol.27, issue.3, pp.859-897, 1998. ,
DOI : 10.1214/aos/1018031261
Bandelet image approximation and compression, SIAM Multiscale Modelling and Simulation, vol.4, issue.3, pp.992-1039, 2005. ,
[A Wavelet Tour of Signal Processing, 1999. ,
Non-local sparse models for image restoration, 2009 IEEE 12th International Conference on Computer Vision, 2009. ,
DOI : 10.1109/ICCV.2009.5459452
Sparse Modeling of Textures, Journal of Mathematical Imaging and Vision, vol.27, issue.2, pp.17-31, 2009. ,
DOI : 10.1007/s10851-008-0120-3
Regression shrinkage and selection via the Lasso, Journal of the Royal Statistical Society: Series B, vol.58, issue.1, pp.267-288, 1996. ,
machine., The Annals of Statistics, vol.29, issue.5, pp.1189-1232, 2001. ,
DOI : 10.1214/aos/1013203451
Atomic Decomposition by Basis Pursuit, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.33-61, 1999. ,
DOI : 10.1137/S1064827596304010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.113.7694
Matching pursuits with time-frequency dictionaries, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3397-3415, 1993. ,
DOI : 10.1109/78.258082
Sparse Approximate Solutions to Linear Systems, SIAM Journal on Computing, vol.24, issue.2, p.227, 1995. ,
DOI : 10.1137/S0097539792240406
Embedded image coding using zerotrees of wavelet coefficients, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3445-3462, 1993. ,
DOI : 10.1109/78.258085
<tex>$rm K$</tex>-SVD: An Algorithm for Designing Overcomplete Dictionaries for Sparse Representation, IEEE Transactions on Signal Processing, vol.54, issue.11, pp.4311-4322, 2006. ,
DOI : 10.1109/TSP.2006.881199
Algorithms for non-negative matrix factorization, [Advances in Neural Information Processing Systems, pp.556-562, 2001. ,
Sparse coding for machine learning, image processing and computer vision, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00595312
Convex optimization with sparsity-inducing norms, " in [Optimization for Machine Learning, 2011. ,
Proximal splitting methods in signal processing, " in [Fixed-Point Algorithms for Inverse Problems in Science and Engineering, 2010. ,
Gradient methods for minimizing composite objective function, tech. rep., Center for Operations Research and Econometrics (CORE), 2007. ,
DOI : 10.1007/s10107-012-0629-5
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
An O(n) algorithm for quadratic knapsack problems, Operations Research Letters, vol.3, issue.3, pp.163-166, 1984. ,
DOI : 10.1016/0167-6377(84)90010-5
A linear-time median-finding algorithm for projecting a vector on the simplex of n, Operations Research Letters, vol.8, issue.4, pp.219-222, 1989. ,
DOI : 10.1016/0167-6377(89)90064-3
A note on the group Lasso and a sparse group Lasso, tech. rep, pp.1001-0736, 2010. ,
Collaborative hierarchical sparse modeling, 2010 44th Annual Conference on Information Sciences and Systems (CISS), 2010. ,
DOI : 10.1109/CISS.2010.5464845
URL : http://arxiv.org/abs/1003.0400
Structured sparsity-inducing norms through submodular functions, Adv. NIPS ], 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00511310
Parallel and distributed computation: Numerical Methods, 1989. ,
Augmented Lagrangian methods for learning, selecting and combining features, " in [Optimization for Machine Learning, 2011. ,
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Foundations and Trends?? in Machine Learning, vol.3, issue.1, pp.1-122, 2011. ,
DOI : 10.1561/2200000016
Structured sparsity via alternating directions methods, tech. rep, 2011. ,
A database of human segmented natural images and its application to evaluating segmentation algorithms and measuring ecological statistics, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, 2001. ,
DOI : 10.1109/ICCV.2001.937655
Group sparse coding with a laplacian scale mixture prior, [Advances in Neural Information Processing Systems, 2010. ,
