Freeze the BCI until the user is ready: a pilot study of a BCI inhibitor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we introduce the concept of Brain-Computer Interface (BCI) inhibitor, which is meant to standby the BCI until the user is ready, in order to improve the overall performance and usability of the system. BCI inhibitor can be defined as a system that monitors user's state and inhibits BCI interaction until specific requirements (e.g. brain activity pattern, user attention level) are met. In this pilot study, a hybrid BCI is designed and composed of a classic synchronous BCI system based on motor imagery and a BCI inhibitor. The BCI inhibitor initiates the control period of the BCI when requirements in terms of brain activity are reached (i.e. stability in the beta band). Preliminary results with four participants suggest that BCI inhibitor system can improve BCI performance.
inhibitor.pdf (83.88 Ko) Télécharger le fichier
inria-00634556 , version 1 (07-11-2011)
  • HAL Id : inria-00634556 , version 1
  • ARXIV : 1111.1842
Laurent George, Laurent Bonnet, Anatole Lécuyer. Freeze the BCI until the user is ready: a pilot study of a BCI inhibitor. 5th International Brain-Computer Interface Workshop, Sep 2011, Graz, Austria. ⟨inria-00634556⟩
159 Consultations
94 Téléchargements
