The transformation, of Poisson, binomial and negativebinomial data, Biometrika, vol.354, issue.3, pp.246-254, 1948. ,
Regularization parameter selection methods for ill-posed Poisson maximum likelihood estimation, Inverse Problems, vol.25, issue.9, 2009. ,
DOI : 10.1088/0266-5611/25/9/095005
Dieterlen Wavelet filtering applied to 3D wide field fluorescence microscopy deconvolution, Proceedings PSIP'07, 2007. ,
Image Restoration for Confocal Microscopy: Improving the Limits of Deconvolution, with Application to the Visualization of the Mammalian Hearing Organ, Biophysical Journal, vol.80, issue.5, pp.2455-2470, 2001. ,
DOI : 10.1016/S0006-3495(01)76214-5
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, 2009. ,
DOI : 10.1137/080716542
Fast Discrete Curvelet Transforms, Multiscale Modeling & Simulation, vol.5, issue.3, pp.861-899, 2006. ,
DOI : 10.1137/05064182X
Régularité et parcimonie pour lesprobì emes inverses en imagerie : algorithmes et comparaisons, Traitement du Signal, vol.27, issue.2, pp.187-217, 2010. ,
Complex wavelet regularization for solving inverse problems in remote sensing, 2009 IEEE International Geoscience and Remote Sensing Symposium, 2009. ,
DOI : 10.1109/IGARSS.2009.5417865
URL : https://hal.archives-ouvertes.fr/inria-00417708
An algorithm for total variation minimization and applications, J. Math. Imaging Vis, vol.20, issue.12, pp.89-97, 2004. ,
Wavelet-based restoration methods: application to 3D confocal microscopy images, Wavelets XII, 2007. ,
DOI : 10.1117/12.731438
URL : https://hal.archives-ouvertes.fr/hal-00733457
A forwardbackward algorithm for image restoration with sparse representations, Signal Processing with Adaptative Sparse Structured Representations (SPARS'05), pp.49-52, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00017658
Image analysis using a dual-tree M-band wavelet transform, IEEE Transactions on Image Processing, vol.15, issue.8, pp.2397-2412, 2006. ,
DOI : 10.1109/TIP.2006.875178
URL : https://hal.archives-ouvertes.fr/hal-01330599
Nested Iterative Algorithms for Convex Constrained Image Recovery Problems, SIAM Journal on Imaging Sciences, vol.2, issue.2, pp.730-762, 2009. ,
DOI : 10.1137/080727749
URL : https://hal.archives-ouvertes.fr/hal-00621932
A proximal decomposition method for solving convex variational inverse problems, Inverse Problems, vol.24, issue.6, 2008. ,
DOI : 10.1088/0266-5611/24/6/065014
URL : https://hal.archives-ouvertes.fr/hal-00692901
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Richardson???Lucy algorithm with total variation regularization for 3D confocal microscope deconvolution, Microscopy Research and Technique, vol.59, issue.4, pp.260-266, 2006. ,
DOI : 10.1002/jemt.20294
A Proximal Iteration for Deconvolving Poisson Noisy Images Using Sparse Representations, IEEE Transactions on Image Processing, vol.18, issue.2, pp.310-321, 2009. ,
DOI : 10.1109/TIP.2008.2008223
Analysis versus synthesis in signal priors, Inverse Problems, vol.23, issue.3, pp.947-968, 2007. ,
DOI : 10.1088/0266-5611/23/3/007
Applications of lagrangian-based alternating direction methods and connections to split bregman, UCLA Cam Report, 2009. ,
Restoration of Poissonian Images Using Alternating Direction Optimization, IEEE Transactions on Image Processing, vol.19, issue.12, 2010. ,
DOI : 10.1109/TIP.2010.2053941
Numerical Methods for Nonlinear variation al Problems, 1984. ,
Generalized Cross-Validation as a Method for Choosing a Good Ridge Parameter, Technometrics, vol.5, issue.2, pp.215-223, 1979. ,
DOI : 10.1080/03610927508827223
On the analysis of fluorescence decay kinetics by the method of least-squares, Analytical Biochemistry, vol.59, issue.2, pp.583-598, 1974. ,
DOI : 10.1016/0003-2697(74)90312-1
An iterative technique for the rectification of observed distributions, The Astronomical Journal, vol.79, issue.6, pp.745-765, 1974. ,
DOI : 10.1086/111605
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Memoir on inventing the confocal scanning microscope, Scanning, vol.10, issue.4, pp.128-138, 1988. ,
DOI : 10.1002/sca.4950100403
Regularization Methods for Ill-Posed Problems, 1993. ,
Gradient methods for minimizing composite objective function. CORE Discussion Paper, 2007. ,
Solving Constrained Total-variation Image Restoration and Reconstruction Problems via Alternating Direction Methods, SIAM Journal on Scientific Computing, vol.32, issue.5, 2009. ,
DOI : 10.1137/090774823
A Restoration Method for Confocal Microscopy Using Complex Wavelet Transform, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., 2005. ,
DOI : 10.1109/ICASSP.2005.1415481
Hybrid regularization for data restoration in the presence of Poisson noise Monte-Carlo SURE: A Black- Box Optimization of Regularization Parameters for General Denoising Algorithms, 17th European Signal Processing Conference, pp.1540-1554, 2008. ,
Deconvolution of 3D fluorescence micrographs with automatic risk minimization, 2008 5th IEEE International Symposium on Biomedical Imaging: From Nano to Macro, pp.732-735, 2008. ,
DOI : 10.1109/ISBI.2008.4541100
Bayesian-Based Iterative Method of Image Restoration*, Journal of the Optical Society of America, vol.62, issue.1, pp.55-59, 1972. ,
DOI : 10.1364/JOSA.62.000055
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, pp.259-268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
The dual-tree complex wavelet transform, IEEE Signal Processing Magazine, vol.22, issue.6, pp.123-151, 2005. ,
DOI : 10.1109/MSP.2005.1550194
Signal restoration with overcomplete wavelet transforms: comparison of analysis and synthesis priors, Wavelets XIII, 2009. ,
DOI : 10.1117/12.826663
Deblurring Poissonian images by split Bregman techniques, Journal of Visual Communication and Image Representation, vol.21, issue.3, pp.193-199, 2010. ,
DOI : 10.1016/j.jvcir.2009.10.006
Three-dimensional image formation in confocal microscopy, Journal of Microscopy, vol.1, issue.2, pp.179-194, 1990. ,
DOI : 10.1111/j.1365-2818.1990.tb04774.x
Image Restoration in Fluorescence Microscopy, 1999. ,
The influence of the regularization parameter and the first estimate on the performance of Tikhonov regularized non-linear image restoration algorithms, Journal of Microscopy, vol.198, issue.1, pp.63-75, 2000. ,
DOI : 10.1046/j.1365-2818.2000.00671.x
A quantitative comparison of image restoration methods for confocal microscopy, Journal of Microscopy, vol.185, issue.3, pp.354-365, 1997. ,
DOI : 10.1046/j.1365-2818.1997.d01-629.x
Efficient gradient projection methods for edge-preserving removal of poisson noise, Inverse Problems, vol.25, issue.4, 2009. ,
Framing pyramids, IEEE Transactions on Signal Processing, vol.51, issue.9, pp.2329-2342, 2003. ,
DOI : 10.1109/TSP.2003.815389
