A 2-Approximation for the Minimum Duplication Speciation Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Biology Année : 2011
Aïda Ouangraoua
Krister M. Swenson
Cedric Chauve
We consider the following problem: given a set of gene family trees, spanning a given set of species, find a first speciation which splits these species into two subsets and minimizes the number of gene duplications that happened before this speciation. We call this problem the Minimum Duplication Bipartition Problem. Using a generalization of the Minimum Edge-Cut Problem, we propose a polynomial time 2-approximation algorithm for the Minimum Duplication Bipartition Problem. We apply this algorithm to the inference of species trees on synthetic datasets and on two datasets of eukaryotic species.
Génétique
inria-00635025 , version 1 (24-10-2011)
Aïda Ouangraoua, Krister M. Swenson, Cedric Chauve. A 2-Approximation for the Minimum Duplication Speciation Problem. Journal of Computational Biology, 2011, 18 (9), pp.1041-1053. ⟨10.1089/cmb.2011.0108⟩. ⟨inria-00635025⟩
74 Consultations
0 Téléchargements
