Automated entry system for printed documents, Pattern Recognition, vol.23, issue.11, pp.1141-1154, 1990. ,
DOI : 10.1016/0031-3203(90)90112-X
From splines and snakes to snake splines, Selected Papers from the Workshop on Geometric Reasoning for Perception and Action, pp.264-281, 1993. ,
DOI : 10.1007/3-540-57132-9_15
Extracting lines on handwritten documents by perceptual grouping, in advances in handwiting and drawing: multidisciplinary approach ,
A Hough based algorithm for extracting text lines in handwritten documents, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.774-777, 1995. ,
DOI : 10.1109/ICDAR.1995.602017
Text line and word segmentation of handwritten documents, Pattern Recognition, vol.42, issue.12, pp.3169-3183, 2009. ,
DOI : 10.1016/j.patcog.2008.12.016
Gap metrics for word separation in handwritten lines, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.124-127, 1995. ,
DOI : 10.1109/ICDAR.1995.598958
A review of deformable surfaces: topology, geometry and deformation, Image and Vision Computing, vol.19, issue.14, pp.1023-1040, 2001. ,
DOI : 10.1016/S0262-8856(01)00064-6
URL : https://hal.archives-ouvertes.fr/inria-00615110
Optimal approximations by piecewise smooth functions and associated variational problems, Communications on Pure and Applied Mathematics, vol.3, issue.5, pp.577-685, 1989. ,
DOI : 10.1002/cpa.3160420503
Handwritten Text Line Segmentation by Shredding Text into its Lines, 2009 10th International Conference on Document Analysis and Recognition, pp.626-630, 2009. ,
DOI : 10.1109/ICDAR.2009.243
Text Line Segmentation in Handwritten Document Using a Production System, Ninth International Workshop on Frontiers in Handwriting Recognition, pp.245-250, 2004. ,
DOI : 10.1109/IWFHR.2004.100
Geometric Level Set Methods in Imaging ,Vision,and Graphics, 2003. ,
STACS: new active contour scheme for cardiac MR image segmentation, IEEE Transactions on Medical Imaging, vol.24, issue.5, pp.593-603, 2005. ,
DOI : 10.1109/TMI.2005.843740
A NATURAL LEARNING ALGORITHM BASED ON HOUGH TRANSFORM FOR TEXT LINES EXTRACTION IN HANDWRITTEN DOCUMENTS, Proc. 6th International Workshop on Frontiers in Handwriting Recognition, pp.637-646, 1998. ,
DOI : 10.1142/9789812797650_0014
A Mumford???Shah level-set approach for the inversion and segmentation of X-ray tomography data, Journal of Computational Physics, vol.221, issue.2, pp.539-557, 2007. ,
DOI : 10.1016/j.jcp.2006.06.041
Curvature and the evolution of fronts, Communications in Mathematical Physics, vol.40, issue.4, pp.487-499, 1985. ,
DOI : 10.1007/BF01210742
Handwritten document image segmentation and analysis, Pattern Recognition Letters, vol.14, issue.1, pp.71-78, 1993. ,
DOI : 10.1016/0167-8655(93)90134-Y
Line separation for complex document images using fuzzy run length, Int. Workshop on Document Image Analysis for Libraries, 2004. ,
Gradient Vector Flow, Proc. IEEE Conf. on Comp. Vis. Patt. Recog. (CVPR), pp.66-71, 1997. ,
DOI : 10.1007/978-0-387-31439-6_712
ContributionàContribution`Contributionà la segmentation de textes manuscrits anciens, Confrence Internationale Francophone sur l'Ecrit et le Document, p.6, 2004. ,
URL : https://hal.archives-ouvertes.fr/sic_00001211
A model-based line detection algorithm in documents, International Conference on Document Analysis and Recognition, vol.1, p.44, 2003. ,
Document Image Analysis for World War II Personal Records, International Workshop on Document Image Analysis for Libraries, pp.336-343, 2004. ,
Repulsive attractive network for baseline extraction on document images, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1-10, 1999. ,
DOI : 10.1109/ICASSP.1997.595468
Handwritten Chinese text line segmentation by clustering with distance metric learning, Proc. 11th ICFHR, pp.229-234, 2008. ,
DOI : 10.1016/j.patcog.2008.12.013
Snakes: Active contour models, Proc. 1st ICCV, 987, pp.259-268 ,
DOI : 10.1007/BF00133570
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5318
Segmentation of Curled Textlines using Active Contours, The Eighth IAPR Workshop on Document Analysis Systems, pp.270-277, 2008. ,
Script-Independent Text Line Segmentation in Freestyle Handwritten Documents, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.8, pp.1313-1329, 2008. ,
DOI : 10.1109/TPAMI.2007.70792
Optimal approximation by piecewise smooth functional and associated variational problems ,
Text line segmentation in handwritten documents using Mumford???Shah model, Pattern Recognition, vol.42, issue.12, pp.3136-3145, 2009. ,
DOI : 10.1016/j.patcog.2008.12.021
On the Use of the Io-Sinh Window for Spectrum Analysis, IEEE Transactions on Acoustics, Speech and Signal Processing, issue.1, p.28, 1980. ,
Quelques commentaires sur des représentations temps-fréquence proposées récemment, pp.3-25, 1992. ,
Generalized Phase-Space Distribution Functions, Journal of Mathematical Physics, vol.7, issue.5, pp.781-786, 1966. ,
DOI : 10.1063/1.1931206
Sur une formulation générale de la représentation en temps et en fréquence dans l'analyse des signaux d'´ energie finie, CR. Acad. Sci. Paris, vol.283, pp.1049-1051, 1976. ,
The Wigner distribution -A tool for time frequency analysis, Parts I-III, Philips J. Res, vol.35, pp.217-250, 1980. ,
Linear and quadratic time-frequency signal representations, IEEE Signal Processing Magazine, vol.9, issue.2, pp.21-67, 1992. ,
DOI : 10.1109/79.127284
Time-Frequency/Time-Scale Analysis, 1999. ,
On the Quantum Correction For Thermodynamic Equilibrium, Physical Review, vol.40, issue.5, pp.749-759, 1932. ,
DOI : 10.1103/PhysRev.40.749
A general class of estimators for the wigner-ville spectrum of non-stationary processes, Lecture Notes in Control and Information Sciences, vol.62, pp.15-23, 1984. ,
DOI : 10.1007/BFb0004941
Skew angle estimation for printed and handwritten documents using the Wigner???Ville distribution, Image and Vision Computing, vol.20, issue.11, pp.813-824, 2002. ,
DOI : 10.1016/S0262-8856(02)00091-4
Page segmentation and classification. Computer Vision Graphics and Image Processing, pp.484-496, 1992. ,
A general algorithm for document skew angle estimation, Proceedings of International Conference on Image Processing, pp.230-233, 1997. ,
DOI : 10.1109/ICIP.1997.638728
Basu A Hough Transform based Technique for Text Segmentation, Computing Research Repository, 2010. ,
Abd-Almageed, L. Kang and D. Doermann Handwritten Arabic Text Line Segmentation using Affinity Propagation, Document Analysis Systems, pp.135-142, 2010. ,
Unsupervised Block Covering Analysis for Text-Line Segmentation of Arabic Ancient Handwritten Document Images, 2010 20th International Conference on Pattern Recognition, pp.1929-1932, 2010. ,
DOI : 10.1109/ICPR.2010.475
Performance Evaluation of Curled Textlines Segmentation Algorithms, 9th IAPR Workshop on Document Analysis Systems, 2010. ,
