Fractional colorings of cubic graphs with large girth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Discrete Mathematics Année : 2011
We show that every (sub)cubic n-vertex graph with sufficiently large girth has fractional chromatic number at most 2.2978, which implies that it contains an independent set of size at least 0.4352n. Our bound on the independence number is valid for random cubic graphs as well, as it improves existing lower bounds on the maximum cut in cubic graphs with large girth.
KKV11.pdf (371.5 Ko) Télécharger le fichier
inria-00635910 , version 1 (09-11-2011)
  • HAL Id : inria-00635910 , version 1
František Kardoš, Daniel Kráľ, Jan Volec. Fractional colorings of cubic graphs with large girth. SIAM Journal on Discrete Mathematics, 2011, 25 (3), pp.1454-1476. ⟨inria-00635910⟩
147 Consultations
109 Téléchargements
