Improving Offset Assignment for Embedded Processors, Lecture Notes in Computer Science, vol.2017, pp.158-172, 2001. ,
DOI : 10.1007/3-540-45574-4_11
Optimizing stack frame accesses for processors with restricted addressing modes, Software: Practice and Experience, vol.22, issue.2, pp.101-110, 1992. ,
DOI : 10.1002/spe.4380220202
Optimizing Address Code Generation for Array-Intensive DSP Applications, CGO '05: Proceedings of the international symposium on code generation and optimization, pp.141-152, 2005. ,
Addressing optimization for loop execution targeting DSP with auto-increment/decrement architecture, ISSS '98: Proceedings of the 11th international symposium on system synthesis, pp.15-20, 1998. ,
Address assignment in dsp code generation-an integrated approach, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.22, issue.8, pp.976-984, 2003. ,
DOI : 10.1109/TCAD.2003.814955
DSP address optimization using a minimum cost circulation technique, Proceedings of IEEE International Conference on Computer Aided Design (ICCAD) ICCAD-97, pp.100-103, 1997. ,
DOI : 10.1109/ICCAD.1997.643380
MiBench: A free, commercially representative embedded benchmark suite, Proceedings of the Fourth Annual IEEE International Workshop on Workload Characterization. WWC-4 (Cat. No.01EX538), pp.3-14, 2001. ,
DOI : 10.1109/WWC.2001.990739
Address Register Assignment for Reducing Code Size, CC '03: Proceedings of the 12th international conference on Compiler Construction, pp.273-289, 2003. ,
DOI : 10.1007/3-540-36579-6_20
UTDSP BenchMark Suite. http://www.eecg.toronto Offset Assignment Showdown: Evaluation of DSP Address Code Optimization Algorithms, CC '03: Proceedings of the 12th international conference on Compiler Construction, pp.290-302, 1992. ,
Optimized array index computation in DSP programs, Proceedings of 1998 Asia and South Pacific Design Automation Conference, pp.87-92, 1998. ,
DOI : 10.1109/ASPDAC.1998.669411
A uniform optimization technique for offset assignment problems, Proceedings. 11th International Symposium on System Synthesis (Cat. No.98EX210), pp.3-8, 1998. ,
DOI : 10.1109/ISSS.1998.730589
Algorithms for address assignment in DSP code generation, Proceedings of International Conference on Computer Aided Design, pp.109-112, 1996. ,
DOI : 10.1109/ICCAD.1996.569409
Code Generation and Optimization Techniques for Embedded Digital Signal Processors, 1996. ,
DOI : 10.1007/978-94-009-0187-2_7
Storage assignment to decrease code size, ACM Transactions on Programming Languages and Systems, vol.18, issue.3, pp.235-253, 1996. ,
DOI : 10.1145/229542.229543
Scheduling-based code size reduction in processors with indirect addressing mode, Proceedings of the ninth international symposium on Hardware/software codesign , CODES '01, pp.165-169, 2001. ,
DOI : 10.1145/371636.371710
Improving Offset Assignment through Simultaneous Variable Coalescing, ACM Transactions on Embedded Computing Systems (TECS), vol.5, issue.4, pp.864-883, 2006. ,
DOI : 10.1007/978-3-540-39920-9_20
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.114.6058
An ILP based approach to address code generation for digital signal processors, Proceedings of the 16th ACM Great Lakes symposium on VLSI , GLSVLSI '06, pp.37-42, 2006. ,
DOI : 10.1145/1127908.1127919
Storage Assignment Optimizations to Generate Compact and Efficient Code on Embedded DSP, PLDI '99: Proceedings of the ACM SIGPLAN 1999 conference on Programming language design and implementation, pp.128-138, 1999. ,
DSP Code Optimization Utilizing Memory Addressing Operation, IEICE Trans Fundamentals, vol.8, pp.1217-1223, 1996. ,
On the Phase Coupling Problem Between Data Memory Layout Generation and Address Pointer Assignment, SCOPES, pp.152-166, 2004. ,
DOI : 10.1007/978-3-540-30113-4_12
Minimization of data address computation overhead in DSP programs, Proceedings of the 1998 IEEE International Conference on Acoustics, Speech and Signal Processing, ICASSP '98 (Cat. No.98CH36181), pp.3093-3096, 1998. ,
DOI : 10.1109/ICASSP.1998.678180
Storage Assignment Optimizations through Variable Coalescence for Embedded Processors, LCTES '03: Proceedings of the 2003 ACM SIGPLAN conference on Language, compiler, and tool for embedded systems, pp.220-231, 2003. ,
DSPStone " : A DSP-Oriented Benchmarking Methodology, 5th International Conference on Signal Processing Applications and Technology, 1994. ,
