ENMIM: Energetic Normalized Mutual Information Model for Online Multiple Object Tracking with Unlearned Motions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In multiple-object tracking, the lack in prior information limits the association performance. Furthermore, to improve tracking, dynamic models are needed in order to determine the settings of the estimation algorithm. In case of complex motions, the dynamic cannot be learned and the task of tracking becomes difficult. That is why online spatio-temporal motion estimation is of crucial importance. In this paper, we propose a new model for multiple target online tracking: the Energetic Normalized Mutual Information Model (ENMIM). ENMIM combines two algorithms: (i) Quadtree Normalized Mutual Information, QNMI, a recursive partitioning methodology involving a region motion extraction; (ii) an energy minimization approach for data association adapted to the constraint of lack in prior information about motion and based on geometric properties. ENMIM is able to handle typical problems such as large inter-frame displacements, unlearned motions and noisy images with low contrast. The main advantage of ENMIM is its parameterless and its capacity to handle noisy multi-modal images without exploiting any pre-processing step.
inria-00635919 , version 1 (26-10-2011)
Abir El Abed, Séverine Dubuisson, Dominique Béréziat. ENMIM: Energetic Normalized Mutual Information Model for Online Multiple Object Tracking with Unlearned Motions. ACIVS 2007 - 9th International Conference on Advanced Concepts for Intelligent Vision Systems, Aug 2007, Delft, Netherlands. pp.955-967, ⟨10.1007/978-3-540-74607-2_87⟩. ⟨inria-00635919⟩
224 Consultations
0 Téléchargements
