Geodesic Image Normalization in the Space of Diffeomorphisms
Abstract : Quantitative, deformable mappings between images are increasingly important as measurement tools in biology and medicine. The theory of diffeomorphisms (smooth differentiable bijections with differentiable inverse) provides a mathematical foundation for the computation and interpretation of these maps. Miller, in particular, has used this theory to develop image normalization techniques that rely on a distance measurement as a regularizer. Here, we use this metric within a general transformation framework that explicitly parameterizes the image to image mapping as a symmetric geodesic path in the space of diffeomorphisms. The key difference between our approach and Miller's is that ours does not choose a single end-point (or template image) from which to measure the map. Rather, we search for the shortest diffeomorphism (smallest deformation) between images by optimizing the transformation with respect to both of its end-points. This algorithm, geodesic normalization, provides solutions that are invariant to which of the input coordinate systems (images) is chosen as a reference. This allows the method to compute metric distances, have truly symmetric performance and to give full space-time solutions that are invertible and diffeomorphic in the discrete domain. Finally, our algorithm guarantees that our solutions and their inverses are consistent to a sub-pixel level.
Type de document :
Communication dans un congrès
Xavier Pennec and Sarang Joshi. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.125-135, 2006
Liste complète des métadonnées
Littérature citée [29 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00636082
Contributeur : Service Ist Inria Sophia Antipolis-Méditerranée / I3s <>
Soumis le : mercredi 26 octobre 2011 - 16:33:08
Dernière modification le : mercredi 26 octobre 2011 - 16:52:29
Document(s) archivé(s) le : dimanche 4 décembre 2016 - 07:14:57
Fichier
Avants_MFCA06.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00636082, version 1
Collections
Citation
Brian Avants, C.L. Epstein, James C. Gee. Geodesic Image Normalization in the Space of Diffeomorphisms. Xavier Pennec and Sarang Joshi. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.125-135, 2006. 〈inria-00636082〉
Métriques
Consultations de la notice
147
Téléchargements de fichiers
323
