Conference papers
Robustness of Prediction Based Delay Compensation for Nonlinear Systems
Abstract : Control of systems where the information between the controller, actuator, and sensor can be lost or delayed can be challenging with respect to stability and performance. One way to overcome the resulting problems is the use of prediction based compensation schemes. Instead of a single input, a sequence of (predicted) future controls is submitted and implemented at the actuator. If suitable, so-called prediction consistent compensation and control schemes, such as certain predictive control approaches, are used, stability of the closed loop in the presence of delays and packet losses can be guaranteed. In this paper, we show that control schemes employing prediction based delay compensation approaches do posses inherent robustness properties. Specifically, if the nominal closed loop system without delay compensation is ISS with respect to perturbation and measurement errors, then the closed loop system employing prediction based delay compensation techniques is robustly stable. We analyze the influence of the prediction horizon on the robustness gains and illustrate the results in simulation.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00636088
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, October 26, 2011 - 4:37:03 PM
Last modification on : Monday, May 30, 2022 - 5:36:02 PM
Long-term archiving on: : Thursday, November 15, 2012 - 10:36:17 AM
File
gruene_pannek_et_al_ifac_2011....
Identifiers
Collections
Citation
Rolf Findeisen, Lars Grüne, Jürgen Pannek, Paolo Varutti. Robustness of Prediction Based Delay Compensation for Nonlinear Systems. 18th IFAC World Congress, 2011, Milano, Italy. pp.203-208, ⟨10.3182/20110828-6-IT-1002.03090⟩. ⟨inria-00636088⟩
Share
Metrics
Record views
111
Files downloads
248
