Abstract : In this paper the problem of stabilizing large-scale systems by distributed controllers, where the controllers exchange information via a shared limited communication medium is addressed. Event-triggered sampling schemes are proposed, where each system decides when to transmit new information across the network based on the crossing of some error thresholds. Stability of the interconnected large-scale system is inferred by applying a generalized small-gain theorem. Two variations of the event-triggered controllers which prevent the occurrence of the Zeno phenomenon are also discussed.
Claudio de Persis, Rudolf Sailer, Fabian Wirth. On a small-gain approach to distributed event-triggered control. 18th IFAC World Congress, Aug 2011, Milano, Italy. pp.2401-2406, ⟨10.3182/20110828-6-IT-1002.02057⟩. ⟨inria-00636100⟩
