Journal articles
Economic receding horizon control without terminal constraints
Abstract : We consider a receding horizon control scheme without terminal constraints in which the stage cost is de ned by economic criteria, i.e., not necessarily linked to a stabilization or tracking problem. We analyze the performance of the resulting receding horizon controller with a particular focus on the case of optimal steady states for the corresponding averaged in nite horizon problem. Using a turnpike property and suitable controllability properties we prove near optimal performance of the controller and convergence of the closed loop solution to a neighborhood of the optimal steady state. Several examples illustrate our ndings numerically and show how to verify the imposed assumptions.
keyword : sadco
Document type :
Journal articles
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00636102
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, October 26, 2011 - 4:59:33 PM
Last modification on : Friday, October 13, 2017 - 5:08:16 PM
Long-term archiving on: : Thursday, November 15, 2012 - 10:36:30 AM
File
gruene_ecompc_2011.pdf
Identifiers
Collections
Citation
Lars Grüne. Economic receding horizon control without terminal constraints. Automatica, Elsevier, 2013, 49 (3), pp.725-734. ⟨10.1016/j.automatica.2012.12.003⟩. ⟨inria-00636102⟩
Share
Metrics
Record views
83
Files downloads
617
